ArcGIS.Desktop.Mapping Namespace / RasterLayer Class / IsEditable Property
    IsEditable Property (RasterLayer)
    Gets whether a layer is editable.
    Syntax
    Public ReadOnly Property IsEditable As Boolean
    public bool IsEditable {get;}
    Remarks
    Returns true only when (a) you have data source level permission to edit and (b) it is made editable on the map.
    Use the extension method "CanEditData" to determine if the data represented by a MapMember can be edited independently of the TOC Editable state.
    Requirements
