ArcGIS.Desktop.Mapping Namespace / SubtypeGroupLayerCreationParams Class
Members Example
    Represents an object to initialize and create a SubtypeGroupLayer with pre-defined properties such as renderer, visibility etc. for each sublayer.
    Object Model
    SubtypeGroupLayerCreationParams ClassLayer ClassLayer ClassLayer ClassLayer ClassLayer ClassCIMDataConnection ClassDefinitionQuery ClassItem ClassCIMLayerDocument Class
    Syntax
    Public Class SubtypeGroupLayerCreationParams
       Inherits LayerCreationParams
    public class SubtypeGroupLayerCreationParams : LayerCreationParams
    Example
    Create a new SubTypeGroupLayer
              var subtypeGroupLayerCreateParam = new SubtypeGroupLayerCreationParams
                (new Uri(@"c:\data\SubtypeAndDomain.gdb\Fittings"));
              // Define Subtype layers
              var rendererDefn1 = new UniqueValueRendererDefinition(new List<string> { "type" });
              var renderDefn2 = new SimpleRendererDefinition()
                  SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
                        CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
              subtypeGroupLayerCreateParam.SubtypeLayers = new List<SubtypeFeatureLayerCreationParams>()
          //define first subtype layer with unique value renderer
          new SubtypeFeatureLayerCreationParams(new UniqueValueRendererDefinition(new List<string> { "type" }), 1),
          //define second subtype layer with simple symbol renderer
          new SubtypeFeatureLayerCreationParams(renderDefn2, 2)
              // Define additional parameters
              subtypeGroupLayerCreateParam.DefinitionQuery = new DefinitionQuery(whereClause: "Enabled = 1", name: "IsActive");
              subtypeGroupLayerCreateParam.IsVisible = true;
              subtypeGroupLayerCreateParam.MinimumScale = 50000;
              //Note: Needs QueuedTask to run
              SubtypeGroupLayer subtypeGroupLayer2 = LayerFactory.Instance.CreateLayer<SubtypeGroupLayer>(
                            subtypeGroupLayerCreateParam, MapView.Active.Map);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.BaseCreationParams
          ArcGIS.Desktop.Mapping.MapMemberCreationParams
             ArcGIS.Desktop.Mapping.LayerCreationParams
                ArcGIS.Desktop.Mapping.SubtypeGroupLayerCreationParams
    Requirements
