ArcGIS.Desktop.Mapping Namespace / SubtypeGroupLayerCreationParams Class / SubtypeLayers Property
Example
    SubtypeLayers Property (SubtypeGroupLayerCreationParams)
    Gets and sets a list of SubtypeFeatureLayerCreationParams.
    Syntax
    Remarks
    If you do not provide any list, LayerFactory.CreateLayer<T> will create a SubtypeGroupLayer with all subtypes available at the source.
    If you want to create a SubtypeGroupLayer with only a subset of all available subtypes and/or create them with pre-defined renderer, you must provide a list of SubtypeFeatureLayerCreationParams.
    Example
    Create a new SubTypeGroupLayer
      var subtypeGroupLayerCreateParam = new SubtypeGroupLayerCreationParams
        (new Uri(@"c:\data\SubtypeAndDomain.gdb\Fittings"));
      // Define Subtype layers
      var rendererDefn1 = new UniqueValueRendererDefinition(new List<string> { "type" });
      var renderDefn2 = new SimpleRendererDefinition()
        SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
                CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
      subtypeGroupLayerCreateParam.SubtypeLayers = new List<SubtypeFeatureLayerCreationParams>()
          //define first subtype layer with unique value renderer
          new SubtypeFeatureLayerCreationParams(new UniqueValueRendererDefinition(new List<string> { "type" }), 1),
          //define second subtype layer with simple symbol renderer
          new SubtypeFeatureLayerCreationParams(renderDefn2, 2)
      // Define additional parameters
      subtypeGroupLayerCreateParam.DefinitionQuery = new DefinitionQuery(whereClause: "Enabled = 1", name: "IsActive");
      subtypeGroupLayerCreateParam.IsVisible = true;
      subtypeGroupLayerCreateParam.MinimumScale = 50000;
      SubtypeGroupLayer subtypeGroupLayer2 = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<SubtypeGroupLayer>(subtypeGroupLayerCreateParam, map));
    Requirements
