ArcGIS.Desktop.Mapping Namespace / StreamLayer Class / GetExpirationMethod Method
Example
    GetExpirationMethod Method (StreamLayer)
    Gets the current expiration method. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetExpirationMethod() As FeatureExpirationMethod
    public FeatureExpirationMethod GetExpirationMethod()
    Return Value
    Exceptions
    ExceptionDescription
    Stream service data connection is null.
    Example
    Set the Maximum Count of Previous Observations to be Stored in Memory
      // Note: call within QueuedTask.Run()
        //Set Expiration Method and Max Expiration Count
        if (streamLayer.GetExpirationMethod() != FeatureExpirationMethod.MaximumFeatureCount)
          streamLayer.SetExpirationMethod(FeatureExpirationMethod.MaximumFeatureCount);
        streamLayer.SetExpirationMaxCount(15);
        //FYI
        if (streamLayer.IsTrackAware)
          //MaxCount is per track! otherwise for the entire layer
    Set the Maximum Age of Previous Observations to be Stored in Memory
        //Set Expiration Method and Max Expiration Age
        if (streamLayer.GetExpirationMethod() != FeatureExpirationMethod.MaximumFeatureAge)
          streamLayer.SetExpirationMethod(FeatureExpirationMethod.MaximumFeatureAge);
        //set to 12 hours (max is 24 hours)
        streamLayer.SetExpirationMaxAge(new TimeSpan(12, 0, 0));
        //FYI
          //MaxAge is per track! otherwise for the entire layer
    Requirements
