ArcGIS.Desktop.Mapping Namespace / StreamLayer Class
Members Example
    StreamLayer Class
    Represents layer with a collection of real-time features and their visual representation.
    Object Model
    StreamLayer ClassDefinitionQuery ClassCIMRenderer ClassCIMExpressionInfo ClassCIMDataConnection ClassTimeExtent ClassCIMBaseLayer ClassGeometry ClassElevationTypeDefinition ClassRealtimeFeatureClass ClassGeometry ClassCIMRenderer ClassSelection ClassSpatialReference ClassTable ClassTimeParameters ClassSurfaceZsResult ClassCIMSymbol ClassMap ClassILayerContainer InterfaceEnvelope ClassRowCursor ClassRealtimeCursor ClassRowCursor ClassSelection ClassDefinitionQuery ClassRealtimeCursor Class
    Syntax
    Remarks
    Stream layer is a type of FeatureLayer.To create a StreamLayer, you must call CreateLayer method of the LayerFactory class, instead of directly using a constructor.
    When you use LayerFactory.CreateLayer<T>, you need to pass in a FeatureLayerCreationParams. You should set UniqueValueRendererDefinition and ClassBreaksRendererDefinition in a FeatureLayerCreationParams only when the source stream service has associated archieved feature service layer. See ArcGIS.Core.Data.Realtime.StreamServiceFeatureClassDefinition.GetArchiveFeatureServiceLayerURL for details. That is because at the creation time a stream layer starts with empty set of features.
    You can call FeatureLayer.CreateRenderer anytime later once you have sufficient features to compute and assign a ArcGIS.Core.CIM.CIMUniqueValueRenderer or ArcGIS.Core.CIM.CIMClassBreaksRenderer to a stream layer.
    Example
    Create Stream Layer with URI
      // Note: call within QueuedTask.Run()
        var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
        var createParam = new FeatureLayerCreationParams(new Uri(url))
          IsVisible = false //turned off by default
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(createParam, map);
        //or use "original" create layer (will be visible by default)
        Uri uri = new Uri(url);
        streamLayer = LayerFactory.Instance.CreateLayer(uri, map) as StreamLayer;
        streamLayer.SetVisibility(false);//turn off
    Create a stream layer with a definition query
        //Must be on the QueuedTask
        var lyrCreateParam = new FeatureLayerCreationParams(new Uri(url))
          IsVisible = true,
          DefinitionQuery = new DefinitionQuery(whereClause: "RWY = '29L'", name: "Runway")
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(lyrCreateParam, map);
    Retrieve the current observation renderer
        var renderer = streamLayer.GetRenderer();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Mapping.MapMember
             ArcGIS.Desktop.Mapping.Layer
                ArcGIS.Desktop.Mapping.BasicFeatureLayer
                   ArcGIS.Desktop.Mapping.FeatureLayer
                      ArcGIS.Desktop.Mapping.StreamLayer
    Requirements
