ArcGIS.Desktop.Mapping Namespace / StreamLayer Class / SearchAndSubscribe Method
A null query filter will search all rows and all rows that become available will be retrieved.
If set to true, all the entries in ArcGIS.Core.Data.Realtime.RealtimeCursor will reference the most current row returned by ArcGIS.Core.Data.Realtime.RealtimeCursor.Current. To ensure all the entries in ArcGIS.Core.Data.Realtime.RealtimeCursor remain unique, set useRecyclingCursor to false. The default is true.
Example
    SearchAndSubscribe Method (StreamLayer)
    Searches the table for existing rows using the query criteria and then subscribes to receive row events. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function SearchAndSubscribe( _
       ByVal queryFilter As QueryFilter, _
       ByVal useRecyclingCursor As Boolean _
    ) As RealtimeCursor
    Parameters
    queryFilter
    useRecyclingCursor
    Return Value
    A ArcGIS.Core.Data.Realtime.RealtimeCursor that encapsulates the retrieved rows, as well as provides facilities to wait for new row events.
    Exceptions
    ExceptionDescription
    Stream Layer was disconnected from its underlying feature class.
    A geodatabase-related exception has occurred.
    Remarks
    This operation is atomic. It is guaranteed that the returned ArcGIS.Core.Data.Realtime.RealtimeCursor will correctly reflect any insert or delete operations that occured at any time during the exection of this method. Use ArcGIS.Core.Data.Realtime.RealtimeFeatureClass.SearchAndSubscribe to search and subscribe on any thread. If no query filter is set, all pre-existing rows will be searched and all rows that become available after subscribing will be retrieved.
    Example
    Search And Subscribe for Streaming Data
      // Note: call within QueuedTask.Run()
        //query filter can be null to search and retrieve all rows
        //true means recycling cursor
        using (var rc = streamLayer.SearchAndSubscribe(qfilter, true))
          //waiting for new features to be streamed
          //default is no cancellation
          while (rc.WaitForRowsAsync().Result)
            while (rc.MoveNext())
              using (var row = rc.Current)
                //determine the origin of the row event
                switch (row.GetRowSource())
                  case RealtimeRowSource.PreExisting:
                    //pre-existing row at the time of subscribe
                    continue;
                  case RealtimeRowSource.EventInsert:
                    //row was inserted after subscribe
                    continue;
                  case RealtimeRowSource.EventDelete:
                    //row was deleted after subscribe
                    continue;
        }//row cursor is disposed. row cursor is unsubscribed
        //....or....
        //Use the feature class instead of the layer
        using var rfc = streamLayer.GetFeatureClass();
        //non-recycling cursor - 2nd param "false"
        using (RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false))
            //etc
    Search And Subscribe With Cancellation
        //Recycling cursor - 2nd param "true"
        //or streamLayer.Subscribe(qfilter, true) to just subscribe
          //auto-cancel after 20 seconds
          var cancel = new CancellationTokenSource(new TimeSpan(0, 0, 20));
          //catch TaskCanceledException
          try
            while (rc.WaitForRowsAsync(cancel.Token).Result)
              //check for row events
                using var row = rc.Current;
                //etc
          catch (TaskCanceledException)
            //Handle cancellation as needed
          cancel.Dispose();
    Explicitly Cancel WaitForRowsAsync
      RealtimeCursor rc = null;
      bool SomeConditionForCancel = false;
      //somewhere in our code we create a CancellationTokenSource
      var cancel = new CancellationTokenSource();
      //call cancel on the CancellationTokenSource anywhere in
      //the add-in, assuming the CancellationTokenSource is in scope
      if (SomeConditionForCancel)
        cancel.Cancel();//<-- will cancel the token
      //Within QueuedTask we are subscribed! streamLayer.Subscribe() or SearchAndSubscribe()
      try
        //TaskCanceledException will be thrown when the token is cancelled
            //etc
      cancel.Dispose();
    Requirements
