ArcGIS.Desktop.Mapping Namespace / StreamLayer Class / SetExpirationMethod Method
The ArcGIS.Core.CIM.FeatureExpirationMethod value indicates whether features will be expired or removed based on their age or feature count.
Example
    SetExpirationMethod Method (StreamLayer)
    Sets the expiration method to the table. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetExpirationMethod( _
       ByVal featureExpirationMethod As FeatureExpirationMethod _
    public void SetExpirationMethod(
       FeatureExpirationMethod featureExpirationMethod
    Parameters
    Exceptions
    ExceptionDescription
    Stream service data connection is null.
    Example
    Set the Maximum Count of Previous Observations to be Stored in Memory
      // Note: call within QueuedTask.Run()
        //Set Expiration Method and Max Expiration Count
        if (streamLayer.GetExpirationMethod() != FeatureExpirationMethod.MaximumFeatureCount)
          streamLayer.SetExpirationMethod(FeatureExpirationMethod.MaximumFeatureCount);
        streamLayer.SetExpirationMaxCount(15);
        //FYI
        if (streamLayer.IsTrackAware)
          //MaxCount is per track! otherwise for the entire layer
    Set the Maximum Age of Previous Observations to be Stored in Memory
        //Set Expiration Method and Max Expiration Age
        if (streamLayer.GetExpirationMethod() != FeatureExpirationMethod.MaximumFeatureAge)
          streamLayer.SetExpirationMethod(FeatureExpirationMethod.MaximumFeatureAge);
        //set to 12 hours (max is 24 hours)
        streamLayer.SetExpirationMaxAge(new TimeSpan(12, 0, 0));
        //FYI
          //MaxAge is per track! otherwise for the entire layer
    Requirements
