ArcGIS.Core.Geometry Namespace / GeometryBuilderEx Class / IsEmpty Property
Example
    IsEmpty Property (GeometryBuilderEx)
    Gets a value indicating if this instance is empty.
    Syntax
    Public MustOverride ReadOnly Property IsEmpty As Boolean
    public abstract bool IsEmpty {get;}
    Property Value
    True if the this instance is empty and false otherwise.
    Example
    MapPoint Builder Properties
      // MapPointBuilderEx constructors can run on any thread.
      MapPoint point1 = null;
      MapPoint point2 = null;
      SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(54004);
      MapPointBuilderEx mapPointBuilder = new MapPointBuilderEx(100, 200, spatialReference);
      SpatialReference sr = mapPointBuilder.SpatialReference; // sr != null
      int wkid = sr.Wkid; // wkid = 54004
      bool hasZ = mapPointBuilder.HasZ;   // hasZ = false
      bool hasM = mapPointBuilder.HasM;   // hasM = false
      bool hasID = mapPointBuilder.HasID; // hasID = false
      bool isEmpty = mapPointBuilder.IsEmpty; // isEmpty = false
      double x = mapPointBuilder.X;   // x = 100
      double y = mapPointBuilder.Y;   // y = 200
      double z = mapPointBuilder.Z;   // z = 0, default value
      double m = mapPointBuilder.M;   // m is NaN, default value
      double id = mapPointBuilder.ID; // id = 0, default value
      // Do something with the builder
      mapPointBuilder.Z = 12; // Setting the z-value automatically sets HasZ property to true
      point1 = mapPointBuilder.ToGeometry();
      sr = point1.SpatialReference; // sr != null
      hasZ = point1.HasZ;   // hasZ = true
      hasM = point1.HasM;   // hasM = false
      hasID = point1.HasID; // hasID = false
      x = point1.X;   // x = 100
      y = point1.Y;   // y = 200
      z = point1.Z;   // z = 12
      m = point1.M;   // m is NaN, default value
      id = point1.ID; // id = 0, default value
      // Change some of the builder properties
      mapPointBuilder.SetValues(11, 22);
      mapPointBuilder.HasZ = false;
      mapPointBuilder.HasM = true;
      mapPointBuilder.M = 44;
      // Create another point
      point2 = mapPointBuilder.ToGeometry();
      bool isEqual = point1.IsEqual(point2); // isEqual = false
      // Set the builder to empty
      // Sets X and Y to NaN. Sets other attributes to the default values.
      // Does not change the attribute awareness.
      mapPointBuilder.SetEmpty();
      MapPoint point3 = mapPointBuilder.ToGeometry();
      sr = point3.SpatialReference; // sr != null
      hasZ = point3.HasZ;        // hasZ = false
      hasM = point3.HasM;        // hasM = true
      hasID = point3.HasID;      // hasID = false
      isEmpty = point3.IsEmpty;  // isEmpty = true
      x = point3.X;              // x is NaN
      y = point3.Y;              // y is NaN
      z = point3.Z;              // z = 0, default value
      m = point3.M;              // m is NaN, default value
      id = point3.ID;            // ID = 0, default value
      // Create a builder from a point
      mapPointBuilder = new MapPointBuilderEx(point2); // point1 = (11, 22, 0, 44, 0)
      hasM = mapPointBuilder.HasM;        // hasM = true
      x = mapPointBuilder.X;              // x = 11
      y = mapPointBuilder.Y;              // y = 22
      m = mapPointBuilder.M;              // m = 44
      id = mapPointBuilder.ID;            // ID = 0, default value
      // Setting attribute values automatically sets the corresponding flag to true
      mapPointBuilder.Z = 150;
      mapPointBuilder.ID = 2;
      // Remove the spatial reference
      mapPointBuilder.SpatialReference = null;
      MapPoint point4 = mapPointBuilder.ToGeometry() as MapPoint;
      sr = point3.SpatialReference; // sr = null
      hasZ = point3.HasZ;        // hasZ = true
      hasID = point3.HasID;      // hasID = true
      isEmpty = point3.IsEmpty;  // isEmpty = false
      x = point3.X;              // x = 11
      y = point3.Y;              // y = 22
      z = point3.Z;              // z = 150
      m = point3.M;              // m = 44
      id = point3.ID;            // ID = 2
    Requirements
