ArcGIS.Core.Geometry Namespace / Patch Class / Material Property
Example
    Material Property
    Gets or sets the material for this patch by reference.
    Syntax
    public Material Material {get; set;}
    Public Property Material As Material
    Remarks
    Patches may share the same material. The getter returns the material for this patch builder by reference. A change to the returned material changes the material in any patch containing the material. Patches that share the material will have the same material index returned from GetPatchMaterialIndex. To remove the material from this patch, set the material to null.
    Example
    Construct Multipatch via MultipatchBuilderEx
      var coords_face1 = new List<Coordinate3D>()
      new Coordinate3D(12.495461061000071,41.902603910000039,62.552700000000186),
      new Coordinate3D(12.495461061000071,41.902603910000039,59.504700000004959),
      new Coordinate3D(12.495461061000071,41.902576344000067,59.504700000004959),
      new Coordinate3D(12.495461061000071,41.902576344000067,62.552700000000186),
      var coords_face2 = new List<Coordinate3D>()
      new Coordinate3D(12.495461061000071, 41.902576344000067, 62.552700000000186),
      new Coordinate3D(12.495461061000071, 41.902576344000067, 59.504700000004959),
      new Coordinate3D(12.495488442000067, 41.902576344000067, 59.504700000004959),
      new Coordinate3D(12.495488442000067, 41.902576344000067, 62.552700000000186),
      var coords_face3 = new List<Coordinate3D>()
      new Coordinate3D(12.495488442000067, 41.902603910000039, 59.504700000004959),
      new Coordinate3D(12.495488442000067, 41.902603910000039, 62.552700000000186),
      var coords_face4 = new List<Coordinate3D>()
      new Coordinate3D(12.495461061000071, 41.902603910000039, 59.504700000004959),
      var coords_face5 = new List<Coordinate3D>()
      new Coordinate3D(12.495461061000071, 41.902603910000039, 62.552700000000186),
      var coords_face6 = new List<Coordinate3D>()
      // materials
      var materialRed = new BasicMaterial();
      materialRed.Color = System.Windows.Media.Colors.Red;
      var materialTransparent = new BasicMaterial();
      materialTransparent.Color = System.Windows.Media.Colors.White;
      materialTransparent.TransparencyPercent = 80;
      var blueTransparent = new BasicMaterial(materialTransparent);
      blueTransparent.Color = System.Windows.Media.Colors.SkyBlue;
      // create a list of patch objects
      var patchesList = new List<Patch>();
      // create the multipatchBuilderEx object
      var mpb = new ArcGIS.Core.Geometry.MultipatchBuilderEx();
      // make each patch using the appropriate coordinates and add to the patch list
      var patch = mpb.MakePatch(PatchType.Triangles);
      patch.Coords = coords_face1;
      patchesList.Add(patch);
      patch.Coords = coords_face2;
      patch.Coords = coords_face3;
      patch.Coords = coords_face4;
      patch.Coords = coords_face5;
      patch.Coords = coords_face6;
      patchesList[0].Material = materialRed;
      patchesList[1].Material = materialTransparent;
      patchesList[2].Material = materialRed;
      patchesList[3].Material = materialRed;
      patchesList[4].Material = materialRed;
      patchesList[5].Material = blueTransparent;
      // assign the patches to the multipatchBuilder
      mpb.Patches = patchesList;
      // check which patches currently contain the material
      var red = mpb.QueryPatchIndicesWithMaterial(materialRed);
      //   red should be [0, 2, 3, 4]
      // call ToGeometry to get the multipatch
      multipatch = mpb.ToGeometry() as Multipatch;
    Construct Multipatch from another Multipatch
      TextureResource brickTextureResource = null;
      BasicMaterial brickMaterialTexture = new BasicMaterial();
      var coords = new List<Coordinate3D>();
      var builder = new ArcGIS.Core.Geometry.MultipatchBuilderEx(multipatch);
      // check some properties
      bool hasM = builder.HasM;
      bool hasZ = builder.HasZ;
      bool hasID = builder.HasID;
      bool isEmpty = builder.IsEmpty;
      bool hasNormals = builder.HasNormals;
      var patches = builder.Patches;
      int patchCount = patches.Count;
      // if there's some patches
      if (patchCount > 0)
        int pointCount = builder.GetPatchPointCount(0);
        // replace the first point in the first patch
        if (pointCount > 0)
          // get the first point
          var pt = builder.GetPoint(0, 0);
          builder.SetPoint(0, 0, mapPoint);
        // check which patches currently contain the texture
        var texture = builder.QueryPatchIndicesWithTexture(brickTextureResource);
        // assign a texture material
        patches[0].Material = brickMaterialTexture;
      // update the builder for M awareness
      builder.HasM = true;
      // synchronize the patch attributes to match the builder attributes
      //   in this instance because we just set HasM to true on the builder, each patch will now get a default M value for it's set of coordinates
      builder.SynchronizeAttributeAwareness();
      multipatch = builder.ToGeometry() as Multipatch;
      // multipatch.HasM will be true
    Construct 3D special Multipatch shapes
      var sr = MapView.Active.Map.SpatialReference;
      var extent = MapView.Active.Extent;
      var center = extent.Center;
      var centerZ = MapPointBuilderEx.CreateMapPoint(center.X, center.Y, 500, sr);
      // cube
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cube, centerZ, 200, sr);
      // tetrahedron
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Tetrahedron, centerZ, 200, sr);
      // diamond
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Diamond, centerZ, 200, sr);
      // hexagon
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Hexagon, centerZ, 200, sr);
      // sphere frame
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.SphereFrame, centerZ, 200, 0.8, sr);
      // sphere
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Sphere, centerZ, 200, 0.8, sr);
      // cylinder
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cylinder, centerZ, 200, 0.8, sr);
      // cone
      multipatch = ArcGIS.Core.Geometry.MultipatchBuilderEx.CreateMultipatch(MultipatchConstructType.Cone, centerZ, 200, 0.8, sr);
      // use the builder to add materials or textures
      //   - create a cone with a material
      builder = new MultipatchBuilderEx(MultipatchConstructType.Cone, centerZ, 200, 0.8, sr);
      BasicMaterial faceMaterial = new BasicMaterial();
      faceMaterial.Color = System.Windows.Media.Color.FromRgb(255, 0, 0);
      faceMaterial.Shininess = 150;
      faceMaterial.TransparencyPercent = 50;
      faceMaterial.EdgeWidth = 20;
      foreach (var patch in builder.Patches)
        patch.Material = faceMaterial;
    Requirements
