ArcGIS.Desktop.Mapping Namespace / PDFFormat Class / MasterPassword Property
Example
    Gets or sets the master password to protect the file. The password will need to be entered for editing and printing file.
    Syntax
    Public Property MasterPassword As String
    public string MasterPassword {get; set;}
    Example
    Export a layout to PDF
      //Export a single page layout to PDF.
      //Create a PDF format with appropriate settings
      //BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
      string filePath = @"Path and file name for the output export file";
      PDFFormat PDF = new PDFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        DoCompressVectorGraphics = true,
        DoEmbedFonts = true,
        HasGeoRefInfo = true,
        ImageCompression = ImageCompression.Adaptive,
        ImageQuality = ImageQuality.Best,
        LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
      //Check to see if the path is valid and export
      if (PDF.ValidateOutputFilePath())
        //Note: Must be on QueuedTask.Run
        layout.Export(PDF);  //Export the layout to PDF on the worker thread
    Export a map series to single PDF
      //Export a map series with multiple pages to a single PDF.
      //Create PDF format with appropriate settings
      PDFFormat MS_PDF = new PDFFormat()
        Resolution = 300,
      //Set up map series export options
      MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
        ExportPages = ExportPages.Custom,  //Provide a specific list of pages
        CustomPages = "1-3, 5",  //Only used if ExportPages.Custom is set
        ExportFileOptions = ExportFileOptions.ExportAsSinglePDF,  //Export all pages to a single, multi-page PDF
        ShowSelectedSymbology = false  //Do no show selection symbology in the output
      //Export on the worker thread
      if (MS_PDF.ValidateOutputFilePath())
        layout.Export(MS_PDF, MS_ExportOptions);  //Export to PDF
    Requirements
