Public Property SecurityPermission As PDFSecurityPermission
public PDFSecurityPermission SecurityPermission {get; set;}
The values available are defined in PDFSecurityPermission.
The default value is PDFSecurityPermission.None.
//Export a single page layout to PDF.
//Create a PDF format with appropriate settings
//BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
string filePath = @"Path and file name for the output export file";
PDFFormat PDF = new PDFFormat()
OutputFileName = filePath,
Resolution = 300,
DoCompressVectorGraphics = true,
DoEmbedFonts = true,
HasGeoRefInfo = true,
ImageCompression = ImageCompression.Adaptive,
ImageQuality = ImageQuality.Best,
LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
//Check to see if the path is valid and export
if (PDF.ValidateOutputFilePath())
//Note: Must be on QueuedTask.Run
layout.Export(PDF); //Export the layout to PDF on the worker thread
//Export a map series with multiple pages to a single PDF.
//Create PDF format with appropriate settings
PDFFormat MS_PDF = new PDFFormat()
Resolution = 300,
//Set up map series export options
MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
ExportPages = ExportPages.Custom, //Provide a specific list of pages
CustomPages = "1-3, 5", //Only used if ExportPages.Custom is set
ExportFileOptions = ExportFileOptions.ExportAsSinglePDF, //Export all pages to a single, multi-page PDF
ShowSelectedSymbology = false //Do no show selection symbology in the output
//Export on the worker thread
if (MS_PDF.ValidateOutputFilePath())
layout.Export(MS_PDF, MS_ExportOptions); //Export to PDF
