ArcGIS.Core.Data.LinearReferencing Namespace / RouteEventSource Class / GetErrors Method
Example
    GetErrors Method (RouteEventSource)
    Gets the list of errors that occured during the creation of a RouteEventSource using the dynamic segmentation process.
    Syntax
    Exceptions
    ExceptionDescription
    The field containing errors does not exist in the route event source.
    Example
    Create a RouteEventSource via dynamic segmentation process for line events
      static void CreateLineEventSource(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string toMeasureFieldName = "toMeasure", string fromMeasureFieldName = "fromMeasure", string offsetFieldName = "Offset")
        using (FeatureClass routesFeatureClass = geodatabase.OpenDataset<FeatureClass>(routeFeatureClassName))
        using (Table eventsTable = geodatabase.OpenDataset<Table>(eventTableName))
          RouteInfo routeInfo = new RouteInfo(routesFeatureClass, routeIdFieldName);
          EventInfo eventInfo = new LineEventInfo(eventsTable, routeIdFieldName, fromMeasureFieldName, toMeasureFieldName, offsetFieldName);
          RouteEventSourceOptions routeEventSourceOptions = new LineEventSourceOptions() { IsPositiveOffsetOnRight = true };
          using (RouteEventSource routeEventSource = new RouteEventSource(routeInfo, eventInfo, routeEventSourceOptions))
          using (RouteEventSourceDefinition routeEventSourceDefinition = routeEventSource.GetDefinition())
            // Locating errors
            IReadOnlyList<RouteEventSourceError> errors = routeEventSource.GetErrors();
            // Route event source fields
            IReadOnlyList<Field> routeEventSourceFields = routeEventSourceDefinition.GetFields();
            // Add RouteEventSource to the ArcGIS Pro map
            FeatureLayerCreationParams layerParams = new FeatureLayerCreationParams(routeEventSource)
              Name = "HighCrashAreas"
            LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
