ArcGIS.Core.Data.LinearReferencing Namespace / RouteEventSource Class
Properties Methods
    RouteEventSource Class Members
    The following tables list the members exposed by RouteEventSource.
    Public Constructors
     NameDescription
    Public Constructor Generates a new route event source feature class using dynamic segmentation.
    Top
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public PropertyGets the RouteEventSourceOptions, which was used during the route event source creation.
    Public PropertyGets the ArcGIS.Core.Data.DatasetType of this derived dataset. (Inherited from ArcGIS.Core.Data.FeatureClass)
    Top
    Public Methods
     NameDescription
    Public Method Performs common statistics functions on one or more fields in this table or feature class. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public MethodCreates an ArcGIS.Core.Data.InsertCursor instance in memory. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method Creates a new feature in the feature class with a system assigned object ID. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClass)
    Public MethodOverloaded.  (Inherited from ArcGIS.Core.Data.Table)
    Public MethodCreates an ArcGIS.Core.Data.UpdateCursor instance in memory. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method Deletes the rows in the database selected by the specified query. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets a set of field names if this table is a 3D object feature layer. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClass)
    Public Method Gets the archive table associated with this table or feature class if it is archived-enabled. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method Gets the possible contingent values for the given field name based on the values of the row buffer. (Inherited from ArcGIS.Core.Data.Table)
    Public MethodGets a IReadOnlyList of controller datasets of a specific ArcGIS.Core.Data.Dataset type that this table or feature class participates in. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method Gets the data store of this dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public MethodGets the RouteEventSourceDefinition of this dataset.
    Public MethodGets the list of errors that occured during the creation of a RouteEventSource using the dynamic segmentation process.
    Public MethodGets the EventInfo object, which holds information about the event table.
    Public MethodGets an ArcGIS.Core.Geometry.Envelope representing the maximum extent of the data that has been stored in the ArcGIS.Core.Data.FeatureClass. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClass)
    Public MethodGets the RouteInfo object, which holds information about the route feature class.
    Public MethodGets the ArcGIS.Core.Data.FeatureDataset in which this feature class is contained. This method must be called on the MCT. Use QueuedTask.Run (Inherited from ArcGIS.Core.Data.FeatureClass)
    Public Method Gets the ID associated with this table. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public MethodGets the ArcGIS.Core.Data.Join object from which this joined table was created. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method Gets the name of the dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public Method Gets the URI path to the dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public MethodGets the ArcGIS.Core.Data.RegistrationType of a dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public Method Gets a value indicating whether this table is a 3D object feature layer. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClass)
    Public Method Gets a value indicating whether this table is archive-enabled. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method Gets a value indicating whether this table supports attachments. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public MethodGets a value indicating whether this Table supports the concept of controller datasets. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method Gets a value indicating whether this feature class supports feature cache. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.FeatureClass)
    Public MethodGets a value indicating whether this Table was obtained as a result of joining a ArcGIS.Core.Data.Table or a ArcGIS.Core.Data.FeatureClass with another ArcGIS.Core.Data.Table or ArcGIS.Core.Data.FeatureClass from the same or different ArcGIS.Core.Data.Datastore. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public MethodCreates a virtual relationship class with the current table as the origin table/feature class and the destinationTable as the destination table/feature class. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public MethodSearches and retrieves specific rows in this ArcGIS.Core.Data.Table that satisfy the criteria set in the queryFilter. If no query filter is set, all rows will be retrieved. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method (Inherited from ArcGIS.Core.Data.Table)
    Public Method Sorts data from this table or feature class. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Table)
    Public Method Validate contingency constraints to distinguish between valid and invalid contingencies. (Inherited from ArcGIS.Core.Data.Table)
    Top
    Extension Methods
     NameDescription
    Public Extension Method Registers an extension id (guid) with the specified table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Extension Method Gets the readonly list of extension ids (guids) registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Extension Method Gets the CIMDataConnection for the specified dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Gets if the specified extension id (guid) is registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Extension Method Gets whether the dataset is a knowledge graph dataset or not. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Removes the extension id (guid) from being registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Top
