ArcGIS.Core.Data Namespace / CoreDataExtensions Class / GetHasActivationExtension Method
The table to check
The extension id (guid)
Example
    Gets if the specified extension id (guid) is registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Syntax
    Public Shared Function GetHasActivationExtension( _
       ByVal table As Table, _
       ByVal extensionId As Guid _
    ) As Boolean
    public static bool GetHasActivationExtension(
       Table table,
       Guid extensionId
    Parameters
    table
    The table to check
    extensionId
    Exceptions
    ExceptionDescription
    Value cannot be null: table
    extension id cannot be empty
    Example
    Table Extension Ids
      // Must be called within QueuedTask.Run
      void ExtensionIds1(Table table)
        // Add an extension id to a table
        // Check documentation for restrictions on backward compatibility - backward
        // compatibility is limited to ArcGIS Pro 3.1 if an extension id is added.
        // Note: This is an extension method. It is for use in addins only and not CoreHost.
        string extension_id_string = "52d8f3be-b73d-4140-beaf-23d4f9b697ea";
        Guid extension_id = Guid.Parse(extension_id_string);
        // Note: Must be within the lambda of   QueuedTask.Run()
        // Register the extension id with the relevant table
        table.AddActivationExtension(extension_id);
        // Remove an extension id from a table
        // Restores backward compatibility assuming no other compatibility limitations are in place.
        table.RemoveActivationExtension(extension_id);
        // Check if a given extension id  is registered with a particular table.
        if (table.GetHasActivationExtension(extension_id))
          //Implement custom logic relevant to presence of extension_id ...
        // Enumerate all extension ids on a given table.
        foreach (Guid ext_id in table.GetActivationExtensions())
          // Logic based on extension ids ...
    Requirements
    ArcGIS Pro version: 3.1 or higher.
