ArcGIS.Desktop.Core Namespace / RasterImageryOptions Class / SetPyramidCompressionQuality Method
The compression quality
    Sets the pyramid compression quality. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetPyramidCompressionQuality( _
       ByVal value As Integer _
    public void SetPyramidCompressionQuality(
       int value
    Parameters
    value
    Exceptions
    ExceptionDescription
    Remarks
    This should only be used when PyramidCompressionType is PyramidCompressionType.JPEG or PyramidCompressionType.JPEG_YCbCr. The compression quality value must be between 1 and 100. If a value is supplied outside this range then it is converted to be within the range.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
