ArcGIS.Desktop.Mapping Namespace / MapMemberIDSet Class
Properties Methods
    MapMemberIDSet Class Members
    The following tables list the members exposed by MapMemberIDSet.
    Public Properties
     NameDescription
    Public Property Gets the total count of records in the MapMemberIDSet.
    Public Property Gets if the MapMemberIDSet is empty.
    Public Property Gets the list of objectIDs that are contained in the MapMemberIDSet associated with the specified mapMember.
    Top
    Public Methods
     NameDescription
    Public MethodOverloaded.
    Public Methodstatic (Shared in Visual Basic)Overloaded.
    Public Methodstatic (Shared in Visual Basic)Creates a MapMemberIDSet> object from a ArcGIS.Core.Data.Knowledge.KnowledgeGraphIDSet. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Creates a MapMemberIDSet object from a KnowledgeGraphLayerIDSet. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Serves as the default hash function.
    Public Method Creates a KnowledgeGraphIDSet from this MapMemberIDSet. This method must be called on the MCT. Use QueuedTask.Run.
    Top
    Public Operators
    Compares two MapMemberIDSet objects to determine whether they are equal.
    Compares two MapMemberIDSet objects to determine whether they are not equal.
    Top
