ArcGIS.Desktop.Mapping Namespace / MapMemberIDSet Class / FromKnowledgeGraphIDSet Method
The map containing the knowledge graph layer.
The knowledge graph ID set to translate.
    FromKnowledgeGraphIDSet Method (MapMemberIDSet)
    Creates a MapMemberIDSet> object from a ArcGIS.Core.Data.Knowledge.KnowledgeGraphIDSet. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function FromKnowledgeGraphIDSet( _
       ByVal map As Map, _
       ByVal kgIDSet As KnowledgeGraphIDSet _
    ) As MapMemberIDSet
    public static MapMemberIDSet FromKnowledgeGraphIDSet(
       Map map,
       KnowledgeGraphIDSet kgIDSet
    Parameters
    map
    kgIDSet
    Return Value
    Exceptions
    ExceptionDescription
    The map is null.
    The map does not contain a KnowledgeGraphLayer.
    The map is not a link chart.
    Remarks
    This method can only be called when the map is a Link Chart. That is Map.MapType is of type ArcGIS.Core.CIM.MapType.LinkChart otherwise an System.InvalidOperationException will be thrown. Note: The Map must contain a KnowledgeGraphLayer. The source of the knowledge graph layer must match the source of the KnowledgeGraphIDSet. If there are multiple KnowledgeGraphLayers in the map then the first one retrieved from the map's collection of layers will be used.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
