ArcGIS.Desktop.Mapping Namespace / MapMemberIDSet Class / FromDictionary Method / FromDictionary<T>(Dictionary<T,Int64[]>) Method
The collection of mapMembers and their corresponding objectIDs
Example
    Creates a MapMemberIDSet object from the dictionary of records.
    Syntax
    Public Overloads Shared Function FromDictionary(Of T As MapMember)( _
       ByVal dict As Dictionary(Of T,Long()) _
    ) As MapMemberIDSet
    public static MapMemberIDSet FromDictionary<T>(
       Dictionary<T,long[]> dict
    where T: MapMember
    Parameters
    dict
    Type Parameters
    T
    Return Value
    A MapMemberIDSet
    Example
    Assign a set of records as Root Nodes
      await QueuedTask.Run(() =>
        var dict = new Dictionary<MapMember, List<long>>();
        dict.Add(entityLayer, oids);
        MapMemberIDSet mmIDSet = MapMemberIDSet.FromDictionary(dict);
        MapView.Active.SetRootNodes(mmIDSet);
    Define and select a set of records as Root Nodes
        dict.Add(entityLayer2, oids2);
        MapView.Active.SelectRootNodes(mmIDSet);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
