ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / CalibrateByMs Method
The multipart to copy and update.
The points with the new M-values. If the X and Y values match a point in the multipart, then the M-value of that point will be updated with the M-value of the input point.
The method to use when updating M-values of points that are not included in points. You can use a combination of update methods by using the bitwise OR operator. For example, to interpolate between the input points and to extrapolate before the input points, use UpdateMMethod.Interpolate | UpdateMMethod.ExtrapolateBefore.
The distance along the multipart that determines if points are considered for calibration. Points that are farther than the distance along the multipart are not calibrated. If you want all the points to be considered for calibration, use the length of the multipart.
Example
    CalibrateByMs Method (IGeometryEngine)
    Calibrates M-values using M-values of input points.
    Syntax
    Parameters
    multipart
    points
    updateMMethod
    cutOffDistance
    Return Value
    An updated version of the input multipart.
    Exceptions
    ExceptionDescription
    The input multipart is null.
    The input multipart is not M-Aware.
    Example
    Calibrate M values using M values from input points - CalibrateByMs
      string json = "{\"hasM\":true,\"paths\":[[[0,0,-1],[1,0,0],[1,1,1],[1,2,2],[3,1,3],[5,3,4],[9,5,5],[7,6,6]]],\"spatialReference\":{\"wkid\":4326}}";
      polyline = PolylineBuilderEx.FromJson(json);
      // Interpolate using points (0, 0, 17), (1, 0, 42), (7, 6, 18)
      List<MapPoint> updatePoints = new(3);
      MapPointBuilderEx builder = new(0, 0)
        M = 17
      updatePoints.Add(builder.ToGeometry() as MapPoint);
      builder.X = 1;
      builder.M = 42;
      builder.X = 7;
      builder.Y = 6;
      builder.M = 18;
      // Calibrate all the points in the polyline
      double cutOffDistance = polyline.Length;
      Polyline updatedPolyline = GeometryEngine.Instance.CalibrateByMs(polyline, updatePoints, UpdateMMethod.Interpolate, cutOffDistance) as Polyline;
      // The points in the updated polyline are
      // (0, 0, 17 ), ( 1, 0, 42 ), ( 1, 1, 38 ), ( 1, 2, 34 ), ( 3, 1, 30 ), ( 5, 3, 26 ), ( 9, 5, 22 ), ( 7, 6, 18 )
      // ExtrapolateBefore using points (1, 2, 42), (9, 5, 18)
      builder.X = 1;
      builder.Y = 2;
      builder.M = 42;
      updatePoints[0] = builder.ToGeometry() as MapPoint;
      builder.X = 9;
      builder.Y = 5;
      builder.M = 18;
      updatePoints[1] = builder.ToGeometry() as MapPoint;
      updatePoints.RemoveAt(2);
      updatedPolyline = GeometryEngine.Instance.CalibrateByMs(polyline, updatePoints, UpdateMMethod.ExtrapolateBefore, cutOffDistance) as Polyline;
      // ( 0, 0, 66 ), ( 1, 0, 58 ), ( 1, 1, 50 ), ( 1, 2, 42 ), ( 3, 1, 3 ), ( 5, 3, 4 ), ( 9, 5, 18 ), ( 7, 6, 6 )
      // ExtrapolateAfter using points (0, 0, 17), (1, 2, 42)
      builder.X = 0;
      builder.Y = 0;
      builder.M = 17;
      updatePoints.Insert(0, builder.ToGeometry() as MapPoint);
      updatedPolyline = GeometryEngine.Instance.CalibrateByMs(polyline, updatePoints, UpdateMMethod.ExtrapolateAfter, cutOffDistance) as Polyline;
      // ( 0, 0, 17 ), ( 1, 0, 0 ), ( 1, 1, 1 ), ( 1, 2, 42 ), ( 3, 1, 50.333333333333333 ), ( 5, 3, 58.666666666666671 ), ( 9, 5, 67 ), ( 7, 6, 75.333333333333343 )
      // ExtrapolateAfter and Interpolate using points (0, 0, 17), (1, 2, 42)
      updatedPolyline = GeometryEngine.Instance.CalibrateByMs(polyline, updatePoints, UpdateMMethod.ExtrapolateAfter | UpdateMMethod.Interpolate, cutOffDistance) as Polyline;
      // (0,0,17),(1,0,25.333333333333336),(1,1,33.666666666666671),(1,2,42),(3,1,50.333333333333336),(5,3,58.666666666666671),(9,5,67),(7,6,75.333333333333343)
    Requirements
