ArcGIS.Core.Geometry Namespace / MultipointBuilderEx Class / GetPoint Method
The point index. Must be in the range [0, Coordinate2Ds.Count - 1] inclusive.
Example
    GetPoint Method (MultipointBuilderEx)
    Gets the MapPoint at the specified point index.
    Syntax
    Public Function GetPoint( _
       ByVal pointIndex As Integer _
    ) As MapPoint
    public MapPoint GetPoint(
       int pointIndex
    Parameters
    pointIndex
    Exceptions
    ExceptionDescription
    The point index is < 0 or the point index is >= Coordinate2Ds.Count.
    Example
    Construct a Multipoint - using MultipointBuilderEx
      Coordinate2D[] coordinate2Ds = new Coordinate2D[] { new Coordinate2D(1, 2), new Coordinate2D(-1, -2) };
      SpatialReference sr = SpatialReferences.WGS84;
      MultipointBuilderEx builder = new MultipointBuilderEx(coordinate2Ds, sr);
      // builder.PointCount = 2
      builder.HasZ = true;
      // builder.Zs.Count = 2
      // builder.Zs[0] = 0
      // builder.Zs[1] = 0
      builder.HasM = true;
      // builder.Ms.Count = 2
      // builder.Ms[0] = NaN
      // builder.Ms[1] = NaN
      builder.HasID = true;
      // builder.IDs.Count = 2
      // builder.IDs[0] = 0
      // builder.IDs[1] = 0
      // set it empty
      builder.SetEmpty();
      // builder.Coords.Count = 0
      // builder.Zs.Count = 0
      // builder.Ms.Count = 0
      // builder.IDs.Count = 0
      // reset coordinates
      List<Coordinate2D> inCoords = new List<Coordinate2D>() { new Coordinate2D(1, 2), new Coordinate2D(3, 4), new Coordinate2D(5, 6) };
      builder.Coordinate2Ds = inCoords;
      // builder.Coords.Count = 3
      // builder.HasZ = true
      // builder.HasM = true
      // builder.HasID = true
      double[] zs = new double[] { 1, 2, 1, 2, 1, 2 };
      builder.Zs = zs;
      // builder.Zs.Count = 6
      double[] ms = new double[] { 0, 1 };
      builder.Ms = ms;
      // coordinates are now   (x, y, z, m, id)
      //  (1, 2, 1, 0, 0), (3, 4, 2, 1, 0) (5, 6, 1, NaN, 0)
      MapPoint mapPointFromBuilder = builder.GetPoint(2);
      // mapPoint.HasZ = true
      // mapPoint.HasM = true
      // mapPoint.HasID = true
      // mapPoint.Z  = 1
      // mapPoint.M = NaN
      // mapPoint.ID = 0
      // add an M to the list
      builder.Ms.Add(2);
      // builder.Ms.count = 3
      //  (1, 2, 1, 0, 0), (3, 4, 2, 1, 0) (5, 6, 1, 2, 0)
      // now get the 2nd point again; it will now have an M value
      // mapPoint.M = 2
      int[] ids = new int[] { -1, -2, -3 };
      // assign ID values
      builder.IDs = ids;
      //  (1, 2, 1, 0, -1), (3, 4, 2, 1, -2) (5, 6, 1, 2, -3)
      // create a new point
      MapPoint pointFromBuilder = MapPointBuilderEx.CreateMapPoint(-300, 400, 4);
      builder.SetPoint(2, pointFromBuilder);
      //  (1, 2, 1, 0, -1), (3, 4, 2, 1, -2) (-300, 400, 4, NaN, 0)
      builder.RemovePoints(1, 3);
      // builder.PointCount = 1
    Modify the points of a Multipoint
      // assume a multiPoint has been built from 4 points
      // the modified multiPoint will have the first point removed and the last point moved
      // use the builderEx constructors which don't need to run on the MCT.
      MultipointBuilderEx builderEx = new MultipointBuilderEx(multipoint);
      // remove the first point
      builderEx.RemovePoint(0);
      // modify the coordinates of the last point
      var ptEx = builderEx.GetPoint(builderEx.PointCount - 1);
      builderEx.RemovePoint(builderEx.PointCount - 1);
      var newPtEx = MapPointBuilderEx.CreateMapPoint(ptEx.X + 1.0, ptEx.Y + 2.0);
      builderEx.AddPoint(newPtEx);
      Multipoint modifiedMultiPointEx = builderEx.ToGeometry() as Multipoint;
    Requirements
