ArcGIS.Core.Geometry Namespace / MultipointBuilderEx Class / RemovePoint Method
The index at which the point will be removed.
Example
    RemovePoint Method
    Remove a point at the specified index.
    Syntax
    Public Sub RemovePoint( _
       ByVal index As Integer _
    public void RemovePoint(
       int index
    Parameters
    index
    Exceptions
    ExceptionDescription
    The point index is < 0 or > Coordinate2Ds.Count.
    Remarks
    If the point has Zs, Ms, or IDs, then the attributes will also be removed from the corresponding lists.
    Example
    Modify the points of a Multipoint
      // assume a multiPoint has been built from 4 points
      // the modified multiPoint will have the first point removed and the last point moved
      // use the builderEx constructors which don't need to run on the MCT.
      MultipointBuilderEx builderEx = new MultipointBuilderEx(multipoint);
      // remove the first point
      builderEx.RemovePoint(0);
      // modify the coordinates of the last point
      var ptEx = builderEx.GetPoint(builderEx.PointCount - 1);
      builderEx.RemovePoint(builderEx.PointCount - 1);
      var newPtEx = MapPointBuilderEx.CreateMapPoint(ptEx.X + 1.0, ptEx.Y + 2.0);
      builderEx.AddPoint(newPtEx);
      Multipoint modifiedMultiPointEx = builderEx.ToGeometry() as Multipoint;
    Requirements
