ArcGIS.Desktop.Core.Geoprocessing Namespace / Geoprocessing Class / OpenToolDialogAsync Method
Use toolboxalias.toolname, toolname_toolboxalias pattern or full path
Optional array of parameter values
Optional array of environment settings (name,value)
callback events are: executeFlags = GPExecuteToolFlags.Default (AddOutputsToMap | RefreshProjectItems) GPExecuteToolFlagsdialogFlags = GPToolDialogFlags.DefaultGPToolDialogFlagsset custom dialog title/>A Task of type IGPResult. See IGPResult for more information.
Example
    Activate Geoprocessing tool dialog.
    Syntax
    Parameters
    toolPath
    values
    environments
    callback
    • OnBeginExecute - param = null. Can be sent miltiple times if user re-run the same tool
    • OnEndExecute - param type IGPResult. Can be sent miltiple times if user re-run the same tool
    • OnClose - param = null, send when user click back or open new tool in the same sub-pane
    executeFlags
    dialogFlags
    dialogTitle
    Return Value
    Example
    Stop a feature class created with GP from automatically adding to the map
      // However, settings in Pro App's Geoprocessing Options will override option set in code
      // for example, in Pro App's Options > Geoprocessing dialog, if you check 'Add output datasets to an open map'
      // then the output WILL BE added to history overriding settings in code
      var CopyfeaturesParams = Geoprocessing.MakeValueArray("C:\\data\\Input.gdb\\PlanA_Roads", "C:\\data\\Input.gdb\\Roads_copy");
      IGPResult gpResult = Geoprocessing.ExecuteToolAsync("management.CopyFeatures", CopyfeaturesParams, null, null, null, GPExecuteToolFlags.None).Result;
      // use the result as needed
    GPExecuteToolFlags.AddToHistory will add the execution messages to History
      // for example, if in Options > Geoprocessing dialog, if you uncheck 'Write geoprocessing operations to Geoprocessing History'
      // then the output will not be added to history.
      var args = Geoprocessing.MakeValueArray("C:\\data\\Vegetation.shp", "NewField", "TEXT");
      var result = Geoprocessing.ExecuteToolAsync("management.AddField", args, null, null, null, GPExecuteToolFlags.AddToHistory);
    Multi Ring Buffer
      //The data referenced in this snippet can be downloaded from the arcgis-pro-sdk-community-samples repo
      //https://github.com/Esri/arcgis-pro-sdk-community-samples
        var paramsArray = Geoprocessing.MakeValueArray(currentTemplate.MapMember.Name,
                    @"C:\Data\FeatureTest\FeatureTest.gdb\Points_MultipleRingBuffer",
                    new List<string> { "1000", "2000" }, "Meters", "Distance",
                    "ALL", "FULL");
        IGPResult gpResult = Geoprocessing.ExecuteToolAsync("Analysis.MultipleRingBuffer", paramsArray).Result;
        var messages = string.IsNullOrEmpty(gpResult.ReturnValue)
                ? $@"Error in Geoprocessing tool: {gpResult.ErrorMessages}"
                : $@"Ok: {gpResult.ReturnValue}";
        // use the messages and the result as needed
    Non-blocking execution of a Geoprocessing tool
      string in_data = @"C:\tools\data.gdb\cities";
      string cities_buff = @"E:\data\data.gdb\cities_2km";
      var valueArray = Geoprocessing.MakeValueArray(in_data, cities_buff, "2000 Meters");
      // to let the GP tool run asynchronously without blocking the main thread
      // use the GPThread option of GPExecuteToolFlags
      GPExecuteToolFlags flags = GPExecuteToolFlags.GPThread;  // instruct the tool run non-blocking GPThread
      IGPResult bufferResult = Geoprocessing.ExecuteToolAsync("Analysis.Buffer", valueArray, null, null, null, flags).Result;
    How to pass parameter with multiple or complex input values
      var environments = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
      string toolName = "Snap_edit";  // or use edit.Snap
      // Snap tool takes multiple inputs each of which has
      // Three (3) parts: a feature class or layer, a string value and a distance
      // Each part is separated by a semicolon - you can get example of sytax from the tool documentation page
      var snapEnv = @"'C:/SnapProject/fgdb.gdb/line_1' END '2 Meters';'C:/SnapProject/fgdb.gdb/points_1' VERTEX '1 Meters';'C:/SnapProject/fgdb.gdb/otherline_1' END '20 Meters'";
      var infc = @"C:/SnapProject/fgdb.gdb/poly_1";
      var snapParams = Geoprocessing.MakeValueArray(infc, snapEnv);
      GPExecuteToolFlags tokens = GPExecuteToolFlags.RefreshProjectItems | GPExecuteToolFlags.GPThread | GPExecuteToolFlags.AddToHistory;
      IGPResult snapResult = Geoprocessing.ExecuteToolAsync(toolName, snapParams, environments, null, null, tokens).Result;
    How to access Geoprocessing History
      string openProjectPath = @"D\DATA\IGPHistoryItemTestProject\IGPHistoryItemTestProject.aprx";
      Project.OpenAsync(openProjectPath);
      MapProjectItem mapProjItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(item => item.Name.Equals("Map", StringComparison.CurrentCultureIgnoreCase));
      // Note: Needs QueuedTask to run
      var map = mapProjItem.GetMap();
      var ftrLayer = map.Layers[0] as FeatureLayer;
      string tool1 = "management.GetCount";
      var args1 = Geoprocessing.MakeValueArray(ftrLayer);
      var env = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
      GPExecuteToolFlags executeFlags = GPExecuteToolFlags.AddToHistory;
      var t = Geoprocessing.ExecuteToolAsync(tool1, args1, env, null, null, executeFlags);
      IEnumerable<IGPHistoryItem> hisItems = Project.Current.GetProjectItemContainer(Geoprocessing.HistoryContainerKey) as IEnumerable<IGPHistoryItem>;
      string hitemID = "";
      string hitemToolPath = "";
      IGPResult hitemGPResult = null;
      DateTime hitemTimeStamp;
      foreach (var hitem in hisItems)
        // common IGPHistoryItem and Item properties
        hitemID = (hitem as Item).ID;
        hitemToolPath = hitem.ToolPath;
        hitemGPResult = hitem.GPResult;
        hitemTimeStamp = hitem.TimeStamp;
        // use the properties as needed
    Add Geometry via MakeValueArray to GP Tool parameter lists
      var tool_name = "analysis.Clip";
      var extent = MapView.Active.Extent;
      var sel_layer = MapView.Active.Map.GetLayersAsFlattenedList()
                        .OfType<FeatureLayer>().FirstOrDefault(l => l.Name == "GreatLakes");
      if (sel_layer == null) return;
      var gdb = Project.Current.DefaultGeodatabasePath;
      var out_fc = System.IO.Path.Combine(gdb, "clipped_lakes_out");
      var rect = GeometryEngine.Instance.Scale(extent, extent.Center, 0.5, 0.5) as Envelope;
      var clip_poly = PolygonBuilderEx.CreatePolygon(rect, rect.SpatialReference);
      //Add the geometry to a list before calling MakeValueArray
      //Envelope and Geometry types are supported
      var geom = new List<object>() { clip_poly };
      var val_array = Geoprocessing.MakeValueArray([sel_layer, geom, out_fc]);
      Geoprocessing.ExecuteToolAsync(tool_name, val_array,
      null, null, null, GPExecuteToolFlags.InheritGPOptions);
    Requirements
