ArcGIS.Desktop.Core.Geoprocessing Namespace / IGPResult Interface
Members Example
    IGPResult Interface
    Geoprocessing tool result object returned by Geoprocessing.ExecuteToolAsync
    Syntax
    Public Interface IGPResult
    public interface IGPResult
    Example
    Multi Ring Buffer
      //The data referenced in this snippet can be downloaded from the arcgis-pro-sdk-community-samples repo
      //https://github.com/Esri/arcgis-pro-sdk-community-samples
        var paramsArray = Geoprocessing.MakeValueArray(currentTemplate.MapMember.Name,
                    @"C:\Data\FeatureTest\FeatureTest.gdb\Points_MultipleRingBuffer",
                    new List<string> { "1000", "2000" }, "Meters", "Distance",
                    "ALL", "FULL");
        IGPResult gpResult = Geoprocessing.ExecuteToolAsync("Analysis.MultipleRingBuffer", paramsArray).Result;
        var messages = string.IsNullOrEmpty(gpResult.ReturnValue)
                ? $@"Error in Geoprocessing tool: {gpResult.ErrorMessages}"
                : $@"Ok: {gpResult.ReturnValue}";
        // use the messages and the result as needed
    Non-blocking execution of a Geoprocessing tool
      string in_data = @"C:\tools\data.gdb\cities";
      string cities_buff = @"E:\data\data.gdb\cities_2km";
      var valueArray = Geoprocessing.MakeValueArray(in_data, cities_buff, "2000 Meters");
      // to let the GP tool run asynchronously without blocking the main thread
      // use the GPThread option of GPExecuteToolFlags
      GPExecuteToolFlags flags = GPExecuteToolFlags.GPThread;  // instruct the tool run non-blocking GPThread
      IGPResult bufferResult = Geoprocessing.ExecuteToolAsync("Analysis.Buffer", valueArray, null, null, null, flags).Result;
    Requirements
