ExecuteToolAsync(String,IEnumerable<String>,IEnumerable<KeyValuePair<String,String>>,CancelableProgressor,GPExecuteToolFlags) Method
Parameters
- toolPath
- Use toolboxalias.toolname or toolname_toolboxalias pattern
- values
- Array of parameter values
- environments
- Array of environment settings - each setting is a key-value pair of environment name and its value). Use MakeEnvironmentArray first to pack all environments.
- progressor
- CancelableProgressor
- flags
- flags = GPExecuteToolFlags.Default (AddOutputsToMap | RefreshProjectItems) GPExecuteToolFlags
Return Value
A task of type IGPResult,
IGPResult
How to execute a Model tool
// get the model tool's parameter syntax from the model's help
var args = Geoprocessing.MakeValueArray(input_roads, buff_dist_field, input_vegetation, output_data);
var result = Geoprocessing.ExecuteToolAsync(tool_path, args);
// use the result as needed
Set Geoprocessing extent environment
var parameters = Geoprocessing.MakeValueArray(@"C:\data\data.gdb\HighwaysUTM11", @"C:\data\data.gdb\Highways_extent");
var ext = Geoprocessing.MakeEnvironmentArray(extent: "460532 3773964 525111 3827494");
var result = Geoprocessing.ExecuteToolAsync("management.CopyFeatures", parameters, ext);
Stop a feature class created with GP from automatically adding to the map
// However, settings in Pro App's Geoprocessing Options will override option set in code
// for example, in Pro App's Options > Geoprocessing dialog, if you check 'Add output datasets to an open map'
// then the output WILL BE added to history overriding settings in code
var CopyfeaturesParams = Geoprocessing.MakeValueArray("C:\\data\\Input.gdb\\PlanA_Roads", "C:\\data\\Input.gdb\\Roads_copy");
IGPResult gpResult = Geoprocessing.ExecuteToolAsync("management.CopyFeatures", CopyfeaturesParams, null, null, null, GPExecuteToolFlags.None).Result;
GPExecuteToolFlags.AddToHistory will add the execution messages to History
// for example, if in Options > Geoprocessing dialog, if you uncheck 'Write geoprocessing operations to Geoprocessing History'
// then the output will not be added to history.
var args = Geoprocessing.MakeValueArray("C:\\data\\Vegetation.shp", "NewField", "TEXT");
var result = Geoprocessing.ExecuteToolAsync("management.AddField", args, null, null, null, GPExecuteToolFlags.AddToHistory);
Multi Ring Buffer
//The data referenced in this snippet can be downloaded from the arcgis-pro-sdk-community-samples repo
//https://github.com/Esri/arcgis-pro-sdk-community-samples
var paramsArray = Geoprocessing.MakeValueArray(currentTemplate.MapMember.Name,
@"C:\Data\FeatureTest\FeatureTest.gdb\Points_MultipleRingBuffer",
new List<string> { "1000", "2000" }, "Meters", "Distance",
"ALL", "FULL");
IGPResult gpResult = Geoprocessing.ExecuteToolAsync("Analysis.MultipleRingBuffer", paramsArray).Result;
var messages = string.IsNullOrEmpty(gpResult.ReturnValue)
? $@"Error in Geoprocessing tool: {gpResult.ErrorMessages}"
: $@"Ok: {gpResult.ReturnValue}";
// use the messages and the result as needed
Non-blocking execution of a Geoprocessing tool
string in_data = @"C:\tools\data.gdb\cities";
string cities_buff = @"E:\data\data.gdb\cities_2km";
var valueArray = Geoprocessing.MakeValueArray(in_data, cities_buff, "2000 Meters");
// to let the GP tool run asynchronously without blocking the main thread
// use the GPThread option of GPExecuteToolFlags
GPExecuteToolFlags flags = GPExecuteToolFlags.GPThread; // instruct the tool run non-blocking GPThread
IGPResult bufferResult = Geoprocessing.ExecuteToolAsync("Analysis.Buffer", valueArray, null, null, null, flags).Result;
How to pass parameter with multiple or complex input values
var environments = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
string toolName = "Snap_edit"; // or use edit.Snap
// Snap tool takes multiple inputs each of which has
// Three (3) parts: a feature class or layer, a string value and a distance
// Each part is separated by a semicolon - you can get example of sytax from the tool documentation page
var snapEnv = @"'C:/SnapProject/fgdb.gdb/line_1' END '2 Meters';'C:/SnapProject/fgdb.gdb/points_1' VERTEX '1 Meters';'C:/SnapProject/fgdb.gdb/otherline_1' END '20 Meters'";
var infc = @"C:/SnapProject/fgdb.gdb/poly_1";
var snapParams = Geoprocessing.MakeValueArray(infc, snapEnv);
GPExecuteToolFlags tokens = GPExecuteToolFlags.RefreshProjectItems | GPExecuteToolFlags.GPThread | GPExecuteToolFlags.AddToHistory;
IGPResult snapResult = Geoprocessing.ExecuteToolAsync(toolName, snapParams, environments, null, null, tokens).Result;
How to pass native objects as parameter values to run geoprocessing tool
string tool2 = "analysis.Buffer";
List<MapPoint> list =
MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
MapPointBuilderEx.CreateMapPoint(1.0, 2.0),
MapPointBuilderEx.CreateMapPoint(2.0, 2.0),
MapPointBuilderEx.CreateMapPoint(2.0, 1.0),
Multipoint multiPoint = MultipointBuilderEx.CreateMultipoint(list);
var spatial_ref = SpatialReferenceBuilder.CreateSpatialReference(3857);
// Note: Needs QueuedTask to run
var args3 = Geoprocessing.MakeValueArray(multiPoint, "memory\\Buffers", "800 meters");
var env1 = Geoprocessing.MakeEnvironmentArray(outputCoordinateSystem: spatial_ref);
var messages = new List<string>(); // list to collect all output messages
var cts = new CancellationTokenSource();
Geoprocessing.ExecuteToolAsync(tool2, args3, env1, cts.Token);
How to access Geoprocessing History
string openProjectPath = @"D\DATA\IGPHistoryItemTestProject\IGPHistoryItemTestProject.aprx";
Project.OpenAsync(openProjectPath);
MapProjectItem mapProjItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(item => item.Name.Equals("Map", StringComparison.CurrentCultureIgnoreCase));
var map = mapProjItem.GetMap();
var ftrLayer = map.Layers[0] as FeatureLayer;
string tool1 = "management.GetCount";
var args1 = Geoprocessing.MakeValueArray(ftrLayer);
var env = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
GPExecuteToolFlags executeFlags = GPExecuteToolFlags.AddToHistory;
var t = Geoprocessing.ExecuteToolAsync(tool1, args1, env, null, null, executeFlags);
IEnumerable<IGPHistoryItem> hisItems = Project.Current.GetProjectItemContainer(Geoprocessing.HistoryContainerKey) as IEnumerable<IGPHistoryItem>;
string hitemID = "";
string hitemToolPath = "";
IGPResult hitemGPResult = null;
DateTime hitemTimeStamp;
foreach (var hitem in hisItems)
// common IGPHistoryItem and Item properties
hitemID = (hitem as Item).ID;
hitemToolPath = hitem.ToolPath;
hitemGPResult = hitem.GPResult;
hitemTimeStamp = hitem.TimeStamp;
// use the properties as needed
How to use Geoprocessing public event
ArcGIS.Desktop.Core.Events.GPExecuteToolEvent.Subscribe(e =>
// Handle the event
string id = e.ID; // Same as history ID
if (e.IsStarting == false) // Execute completed
_ = e.GPResult.ReturnValue;
System.Windows.MessageBox.Show("event triggered.");
Geoprocessing.ExecuteToolAsync("management.GetCount", Geoprocessing.MakeValueArray(@"c:\shape_file.shp"));
Add Geometry via MakeValueArray to GP Tool parameter lists
var tool_name = "analysis.Clip";
var extent = MapView.Active.Extent;
var sel_layer = MapView.Active.Map.GetLayersAsFlattenedList()
.OfType<FeatureLayer>().FirstOrDefault(l => l.Name == "GreatLakes");
if (sel_layer == null) return;
var gdb = Project.Current.DefaultGeodatabasePath;
var out_fc = System.IO.Path.Combine(gdb, "clipped_lakes_out");
var rect = GeometryEngine.Instance.Scale(extent, extent.Center, 0.5, 0.5) as Envelope;
var clip_poly = PolygonBuilderEx.CreatePolygon(rect, rect.SpatialReference);
//Add the geometry to a list before calling MakeValueArray
//Envelope and Geometry types are supported
var geom = new List<object>() { clip_poly };
var val_array = Geoprocessing.MakeValueArray([sel_layer, geom, out_fc]);
Geoprocessing.ExecuteToolAsync(tool_name, val_array,
null, null, null, GPExecuteToolFlags.InheritGPOptions);
