ArcGIS.Desktop.Editing Namespace / AssociationDescription Class / AssociationDescription Constructor / AssociationDescription Constructor(AssociationType,RowHandle,RowHandle)
The association type.
The first row in the association.
The second row in the association.
Example
    Creates a new utility network AssociationDescription of the specified type. Use this constructor for
    Syntax
    Public Function New( _
       ByVal type As AssociationType, _
       ByVal row1 As RowHandle, _
       ByVal row2 As RowHandle _
    public AssociationDescription(
       AssociationType type,
       RowHandle row1,
       RowHandle row2
    Parameters
    type
    row1
    row2
    Remarks
    A utility network structural attachment association is defined between a structure row (row1) and an attachment row (row2). A utility network connectivity association is defined by two junction rows that are not geometrically coincident. A utility network junction-edge "from side" object connectivity association represents a junction or non-spatial junction object (row1) connecting to the "from" side of a non-spatial edge object (row2). A utility network junction-edge "to side" object connectivity association represents a junction or non-spatial junction object (row1) connecting to the "to" side of a non-spatial edge object (row2).
    If type is ArcGIS.Core.Data.UtilityNetwork.AssociationType.Containment, the overloaded AssociationDescription Constructor(AssociationType,RowHandle,RowHandle,Boolean) should be used instead.
    If type is ArcGIS.Core.Data.UtilityNetwork.AssociationType.JunctionEdgeObjectConnectivityMidspan, the overloaded AssociationDescription Constructor(AssociationType,RowHandle,RowHandle,Double) should be used instead.
    Example
    Create a utility network association
      // This routine creates a structural attachment association between a pole and a transformer bank
      static void CreateUNAssociation(UtilityNetwork utilityNetwork, AssetType poleAssetType, Guid poleGlobalID, AssetType transformerBankAssetType, Guid transformerBankGlobalID)
        // Create edit operation
        EditOperation editOperation = new EditOperation();
        editOperation.Name = "Create structural attachment association";
        // Create a RowHandle for the pole
        Element poleElement = utilityNetwork.CreateElement(poleAssetType, poleGlobalID);
        RowHandle poleRowHandle = new RowHandle(poleElement, utilityNetwork);
        // Create a RowHandle for the transformer bank
        Element transformerBankElement =
          utilityNetwork.CreateElement(transformerBankAssetType, transformerBankGlobalID);
        RowHandle transformerBankRowHandle = new RowHandle(transformerBankElement, utilityNetwork);
        // Attach the transformer bank to the pole
        AssociationDescription structuralAttachmentAssociationDescription =
          new AssociationDescription(AssociationType.Attachment, poleRowHandle, transformerBankRowHandle);
        editOperation.Create(structuralAttachmentAssociationDescription);
        editOperation.Execute();
    Create utility network features and associations in a single edit operation
      // This routine creates a pole and a transformer bank, and then creates a structural attachment association between them, all in a single edit operation
      static void CreateUNFeaturesAndAssociations(FeatureLayer transformerBankLayer,
      Dictionary<string, object> transformerBankAttributes, FeatureLayer poleLayer,
      Dictionary<string, object> poleAttributes)
        // Create an EditOperation
        editOperation.Name = "Create pole; create transformer bank; attach transformer bank to pole";
        // Create the transformer bank
        RowToken transformerBankToken = editOperation.Create(transformerBankLayer, transformerBankAttributes);
        // Create a pole
        RowToken poleToken = editOperation.Create(poleLayer, poleAttributes);
        // Create a structural attachment association between the pole and the transformer bank
        RowHandle poleHandle = new RowHandle(poleToken);
        RowHandle transformerBankHandle = new RowHandle(transformerBankToken);
        AssociationDescription poleAttachment =
          new AssociationDescription(AssociationType.Attachment, poleHandle, transformerBankHandle);
        editOperation.Create(poleAttachment);
        // Execute the EditOperation
    Requirements
