Parameters
- name
- String
//Create an empty group element at the root level of the contents pane
//Note: Must be on QueuedTask.Run
//container is IElementContainer - GroupLayer or Layout
GroupElement grp1 = ElementFactory.Instance.CreateGroupElement(
layout, null, "Group");
// *** or ***
//Create a group element inside another group element
//Find an existing group element
GroupElement existingGroup = layout.FindElement("Group") as GroupElement;
//Create on worker thread
GroupElement grp2 = ElementFactory.Instance.CreateGroupElement(
existingGroup, null, "Group in Group");
//Find an element on a layout.
// Reference and load the layout associated with the layout item
Layout mylayout = layoutItem.GetLayout();
if (mylayout != null)
//Find a single specific element
Element rect = mylayout.FindElement("Rectangle") as Element;
//Or use the Elements collection
Element rect2 = mylayout.Elements.FirstOrDefault(item => item.Name.Equals("Rectangle"));
//Create a group with a list of elements at the root level of the contents pane.
//Find an existing elements
var elem1 = layout.FindElement("Polygon 1");
var elem2 = layout.FindElement("Bezier Text");
var elem3 = layout.FindElement("Cloud Shape 2");
//Construct a list and add the elements
var elmList = new List<Element>
elem1,
elem2,
elem3
GroupElement groupWithListOfElementsAtRoot =
layout, elmList, "Group with list of elements at root");
// *** or ***
//Create a group using a list of element names at the root level of the contents pane.
//List of element names
var elmNameList = new[] { "Para Text1", "Line 3" };
var elemToGroup = layout.FindElements(elmNameList);
GroupElement groupWithListOfElementNamesAtRoot =
layout, elemToGroup, "Group with list of element names at root");
