CanSendBackward(GraphicsLayer,Element) Method
Checks whether the given element can be moved back within its parent's
element collection. This method must be called on the MCT. Use QueuedTask.Run.
Parameters
- graphicsLayer
- element
- The element to check
Return Value
True if the element can be moved back.
Ordering: Send backward and Bring forward
await QueuedTask.Run(() =>
//get the current selection set
var sel_elems = graphicsLayer.GetSelectedElements();
//can they be brought forward? This will also check that all elements have the same parent
if (graphicsLayer.CanBringForward(sel_elems))
//bring forward
graphicsLayer.BringForward(sel_elems);
//bring to front (of parent)
//graphicsLayer.BringToFront(sel_elems);
else if (graphicsLayer.CanSendBackward(sel_elems))
//send back
graphicsLayer.SendBackward(sel_elems);
//send to the back (of parent)
//graphicsLayer.SendToBack(sel_elems);
