CanSendBackward(GraphicsLayer,IEnumerable<Element>) Method
Checks whether the given elements can be moved back within their parent's
element collection. This method must be called on the MCT. Use QueuedTask.Run.
Parameters
- graphicsLayer
- elements
- The elements to check
Return Value
True if the elements can be moved back.
Ordering: Send backward and Bring forward
await QueuedTask.Run(() =>
//get the current selection set
var sel_elems = graphicsLayer.GetSelectedElements();
//can they be brought forward? This will also check that all elements have the same parent
if (graphicsLayer.CanBringForward(sel_elems))
//bring forward
graphicsLayer.BringForward(sel_elems);
//bring to front (of parent)
//graphicsLayer.BringToFront(sel_elems);
else if (graphicsLayer.CanSendBackward(sel_elems))
//send back
graphicsLayer.SendBackward(sel_elems);
//send to the back (of parent)
//graphicsLayer.SendToBack(sel_elems);
