ArcGIS.Desktop.Mapping Namespace / GraphicsLayerExtensions Class / FindElement Method
The graphics layer being extended
The name of the element to find. Cannot be null
Example
    FindElement Method (GraphicsLayerExtensions)
    Finds the element recursively with the given name within the GraphicsLayer collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public static Element FindElement(
       GraphicsLayer graphicsLayer,
       string elementName
    Public Shared Function FindElement( _
       ByVal graphicsLayer As GraphicsLayer, _
       ByVal elementName As String _
    ) As Element
    Parameters
    graphicsLayer
    elementName
    Return Value
    The ArcGIS.Desktop.Layouts.Element or null if it is not found
    Exceptions
    ExceptionDescription
    Value cannot be null: elementName
    Remarks
    Find recurses nested groups to find the given element.
    The map view displaying the graphics layer should be initialized.
    Example
    Modify symbology of a Graphic Element
      await QueuedTask.Run(() =>
        //get the first line element in the layer
        var ge = graphicsLayer.FindElement("Line 10") as GraphicElement;
        var graphic = ge.GetGraphic();
        if (graphic is CIMLineGraphic lineGraphic)
          //change its symbol
          lineGraphic.Symbol =
           SymbolFactory.Instance.ConstructLineSymbol(
             SymbolFactory.Instance.ConstructStroke(
         ColorFactory.Instance.BlueRGB, 2, SimpleLineStyle.DashDot)).MakeSymbolReference();
          //apply the change
          ge.SetGraphic(lineGraphic);
    Requirements
