ArcGIS.Desktop.Mapping Namespace / GraphicsLayerExtensions Class / FindElements Method
The graphics layer being extended
The names of the elements to find. Cannot be null
Example
    FindElements Method (GraphicsLayerExtensions)
    Finds the elements recursively with the given names within the GraphicsLayer collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    graphicsLayer
    elementNames
    Return Value
    A IList or an empty list if no elements are found
    Exceptions
    ExceptionDescription
    Value cannot be null: elementNames
    Remarks
    Find recurses nested groups to find the given elements.
    The map view displaying the graphics layer should be initialized.
    Example
    Copy Graphic elements
      await QueuedTask.Run(() =>
        var elems = sourceGraphicsLayer.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
        var copiedElements = targetGraphicsLayer.CopyElements(elems);
    Find Graphic elements
        //Find elements by name
        var elems = graphicsLayer.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
        //Find elements by type
        //Find all point graphics in the Graphics Layer
        var pointGraphics = graphicsLayer.GetElementsAsFlattenedList().Where(elem => elem.GetGraphic() is CIMPointGraphic);
        //Find all line graphics in the Graphics Layer
        var lineGraphics = graphicsLayer.GetElementsAsFlattenedList().Where(elem => elem.GetGraphic() is CIMLineGraphic);
        //Find all polygon graphics in the Graphics Layer
        var polygonGraphics = graphicsLayer.GetElementsAsFlattenedList().Where(elem => elem.GetGraphic() is CIMPolygonGraphic);
        //Find all text graphics in the Graphics Layer
        var textGraphics = graphicsLayer.GetElementsAsFlattenedList().Where(elem => elem.GetGraphic() is CIMTextGraphic);
        //Find all picture graphics in the Graphics Layer
        var pictureGraphic = graphicsLayer.GetElementsAsFlattenedList().Where(elem => elem.GetGraphic() is CIMPictureGraphic);
    Requirements
