public static IReadOnlyList<Element> GetSelectedElements( GraphicsLayer graphicsLayer )
Public Shared Function GetSelectedElements( _ ByVal graphicsLayer As GraphicsLayer _ ) As IReadOnlyList(Of Element)
Parameters
- graphicsLayer
await QueuedTask.Run(() =>
graphicsLayer.RemoveElements(graphicsLayer.GetSelectedElements());
//unselect the first element in the currently selected elements
var elem = graphicsLayer.GetSelectedElements().FirstOrDefault();
if (elem != null)
//Unselect one element
graphicsLayer.UnSelectElement(elem);
//unselect all elements
graphicsLayer.UnSelectElements();
//equivalent to
graphicsLayer.ClearSelection();
ArcGIS.Desktop.Layouts.Events.ElementEvent.Subscribe((args) =>
//check if the container is a graphics layer - could be a Layout (or even map view)
if (args.Container is ArcGIS.Desktop.Mapping.GraphicsLayer graphicsLayer)
//get the total selection count for the container
var count = args.Elements.Count();
//Check count - could have been an unselect or clearselect
if (count > 0)
//this is a selection or add to selection
var elems = graphicsLayer.GetSelectedElements();
//TODO process the selection...
else
//This is an unselect or clear selection
//TODO process the unselect or clear select
var elemsToGroup = graphicsLayer.GetSelectedElements();
//group elements
groupElement = graphicsLayer.GroupElements(elemsToGroup);
var selectedElements = graphicsLayer.GetSelectedElements().ToList();
if (selectedElements?.Count == 0)//must be at least 1.
return;
var elementsToUnGroup = new List<GroupElement>();
//All selected elements should be grouped.
if (selectedElements.Count() == selectedElements.OfType<GroupElement>().Count())
//Convert to a GroupElement list.
elementsToUnGroup = selectedElements.ConvertAll(x => (GroupElement)x);
if (elementsToUnGroup.Count() == 0)
return;
//UnGroup
graphicsLayer.UnGroupElements(elementsToUnGroup);
//get the current selection set
var sel_elems = graphicsLayer.GetSelectedElements();
//can they be brought forward? This will also check that all elements have the same parent
if (graphicsLayer.CanBringForward(sel_elems))
//bring forward
graphicsLayer.BringForward(sel_elems);
//bring to front (of parent)
//graphicsLayer.BringToFront(sel_elems);
else if (graphicsLayer.CanSendBackward(sel_elems))
//send back
graphicsLayer.SendBackward(sel_elems);
//send to the back (of parent)
//graphicsLayer.SendToBack(sel_elems);
var selElementsZOrder = graphicsLayer.GetSelectedElements();
//list out the z order
foreach (var elem in selElementsZOrder)
System.Diagnostics.Debug.WriteLine($"{elem.Name}: z-order {elem.ZOrder}");
//Each selected element will move to a set distance to the upper right.
var selElements = graphicsLayer.GetSelectedElements();
if (selElements.Count == 0)
return;
//Move the element up
foreach (var selElement in selElements)
//Get the element's bounds
var elementPoly = PolygonBuilderEx.CreatePolygon(selElement.GetBounds());
//get the coordinates of the element bounding envelope.
var pointsList = elementPoly.Copy2DCoordinatesToList();
//Move the element's Anchor point to the upper right.
selElement.SetAnchorPoint(pointsList[1]);
