ArcGIS.Desktop.Mapping Namespace / GraphicsLayerExtensions Class / SelectElements Method
The graphics layer being extended
The elements to select. If null then all elements are selected
Example
    SelectElements Method (GraphicsLayerExtensions)
    Select the elements within the GraphicsLayer collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public static void SelectElements(
       GraphicsLayer graphicsLayer,
       IEnumerable<Element> elements
    Public Shared Sub SelectElements( _
       ByVal graphicsLayer As GraphicsLayer, _
       Optional ByVal elements As IEnumerable(Of Element) _
    Parameters
    graphicsLayer
    elements
    Exceptions
    ExceptionDescription
    Remarks
    If a child of a group element is provided in the list of elements to be selected in addition to its parent then the parent is the element selected.
    The map view displaying the graphics layer should be initialized.
    Example
    Select Graphic Elements
      await QueuedTask.Run(() =>
        var elements = graphicsLayer.GetElementsAsFlattenedList()
                            .Where(e => e.Name.StartsWith("Text"));
        graphicsLayer.SelectElements(elements);
        //or select one element
        graphicsLayer.SelectElement(elements.FirstOrDefault());
    Requirements
