ArcGIS.Desktop.Mapping Namespace / Map Class / ClearClipGeometry Method
Example
    Clear the current map clip geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub ClearClipGeometry()
    public void ClearClipGeometry()
    Exceptions
    ExceptionDescription
    Remarks
    If no clipping is set then this is a no-op.
    Example
        var mapWithClip = MapView.Active.Map;
        //Clear the Map clip.
        //If no clipping is set then this is a no-op.
        mapWithClip.ClearClipGeometry();
    Requirements
