ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomTo Method / ZoomTo(BasicFeatureLayer,Int64,Nullable<TimeSpan>,Boolean,Nullable<Double>,Nullable<Double>) Method
The layer containing the feature in which to zoom.
The Object ID of the feature in the layer in which to zoom.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Indicates if the Pitch and Heading should remain the same after the navigation is completed. If false the Heading will be set to 15.0 and the Pitch will be set to -60.0. This parameter only effects 3D views.
The factor by which the feature extent will be scaled before zooming to.
The map scale (in 2D) or distance (in 3D) at which the camera will be placed.
Example
    Zoom the view to the extent of a feature.
    Syntax
    Parameters
    layer
    objectID
    duration
    maintainViewDirection
    factor
    mapScaleOrDistance
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    The map viewer is not initialized.
    The layer is null.
    Example
    Zoom to a specified point
      double x = -122.45;
      double y = 37.75;
      double buffer_size = 0.1;
      //Create a point
      var pt = MapPointBuilderEx.CreateMapPoint(x, y,
                     SpatialReferenceBuilder.CreateSpatialReference(4326));
      //Buffer it - for purpose of zoom
      var poly = GeometryEngine.Instance.Buffer(pt, buffer_size);
      //do we need to project the buffer polygon?
      if (!MapView.Active.Map.SpatialReference.IsEqual(poly.SpatialReference))
        //project the polygon
        poly = GeometryEngine.Instance.Project(poly, MapView.Active.Map.SpatialReference);
      // Must run on MCT.
      QueuedTask.Run(() =>
        //Zoom - add in a delay for animation effect
        MapView.Active.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Zoom To a Point
      // Note: Needs QueuedTask to run
        //Create a point
        var pt = MapPointBuilderEx.CreateMapPoint(x, y, spatialReference);
        mapView.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Rotate the map view
      //Get the camera for the view, adjust the heading and zoom to the new camera position.
      camera = mapView.Camera;
      camera.Heading = heading;
      await mapView.ZoomToAsync(camera, TimeSpan.Zero);
      //Or synchronously
      mapView.ZoomTo(camera, TimeSpan.Zero);
    Requirements
