ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomToAsync Method / ZoomToAsync(BasicFeatureLayer,Int64,Nullable<TimeSpan>,Boolean,Nullable<Double>,Nullable<Double>) Method
The layer containing the feature in which to zoom.
The Object ID of the feature in the layer in which to zoom.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Indicates if the Pitch and Heading should remain the same after the navigation is completed. If false the Heading will be set to 15.0 and the Pitch will be set to -60.0. This parameter only effects 3D views.
The factor by which the feature extent will be scaled before zooming to.
The map scale (in 2D) or distance (in 3D) at which the camera will be placed.
    Zoom the view to the extent of a feature.
    Syntax
    Parameters
    layer
    objectID
    duration
    maintainViewDirection
    factor
    mapScaleOrDistance
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    The map viewer is not initialized.
    The layer is null.
    Requirements
