ArcGIS.Core.Data.LinearReferencing Namespace / RouteInfo Class / LocateFeatures Method / LocateFeatures(Selection,Double,EventTableConfiguration) Method
Selected features to intersect with RouteInfo.
The search radius defines how far a search will be done to find a target route.
Describes an event table to hold events information.
    Computes the intersection between selected features and route features and then stores the resulting route and measure information in a new event table as described by eventTableConfiguration.The search radius defines how far a search will be done to find a target route.
    Syntax
    Parameters
    selectedFeatures
    searchRadius
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    eventTableConfiguration is null.
    Remarks
    If the featureClass is points, the searchRadius will be a numeric value defining how far around each point a search will be done to find a target route.
    If the featureClass is lines, the searchRadius will be a cluster tolerance, which is a numeric value representing the maximum tolerated distance between the input lines and the target routes.
    If the featureClass is polygons, the searchRadius is ignored and no search radius will be used.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
