ArcGIS.Core.CIM Namespace / CIMMaplexGeneralPlacementProperties Class / AllowBorderOverlap Property
Example
    Gets or sets a value indicating whether or not to allow border overlap.
    Syntax
    public bool AllowBorderOverlap {get; set;}
    Public Property AllowBorderOverlap As Boolean
    Example
    Creating an annotation feature class
      Task CreateStandAloneAnnotationFeatureClassAsync(
        Geodatabase geodatabase, SpatialReference spatialReference) => QueuedTask.Run(() =>
        // Creating a Cities annotation feature class
        // with following user defined fields
        // Name
        // GlobalID
        // Annotation feature class name
        string annotationFeatureClassName = "CitiesAnnotation";
        // Create user defined attribute fields for annotation feature class
        FieldDescription globalIDFieldDescription = FieldDescription.CreateGlobalIDField();
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 255);
        // Create a list of all field descriptions
        List<FieldDescription> fieldDescriptions = new List<FieldDescription>
            { globalIDFieldDescription, nameFieldDescription };
        // Create a ShapeDescription object
        ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Polygon, spatialReference);
        // Create general placement properties for Maplex engine
        CIMMaplexGeneralPlacementProperties generalPlacementProperties =
          new CIMMaplexGeneralPlacementProperties
            AllowBorderOverlap = true,
            PlacementQuality = MaplexQualityType.High,
            DrawUnplacedLabels = true,
            InvertedLabelTolerance = 1.0,
            RotateLabelWithDisplay = true,
            UnplacedLabelColor = new CIMRGBColor
              R = 0,
              G = 255,
              B = 0,
              Alpha = 0.5f // Green
        // Create general placement properties for Standard engine
        //CIMStandardGeneralPlacementProperties generalPlacementProperties =
        //  new CIMStandardGeneralPlacementProperties
        //    DrawUnplacedLabels = true,
        //    InvertedLabelTolerance = 3.0,
        //    RotateLabelWithDisplay = true,
        //    UnplacedLabelColor = new CIMRGBColor
        //      R = 255, G = 0, B = 0, Alpha = 0.5f // Red
        // Create annotation  label classes
        // Green label
        CIMLabelClass greenLabelClass = new CIMLabelClass
          Name = "Green",
          ExpressionTitle = "Expression-Green",
          ExpressionEngine = LabelExpressionEngine.Arcade,
          Expression = "$feature.OBJECTID",
          ID = 1,
          Priority = 0,
          Visibility = true,
          TextSymbol = new CIMSymbolReference
            Symbol = new CIMTextSymbol()
              Angle = 45,
              FontType = FontType.Type1,
              FontFamilyName = "Tahoma",
              FontEffects = FontEffects.Normal,
              HaloSize = 2.0,
              Symbol = new CIMPolygonSymbol
                SymbolLayers = new CIMSymbolLayer[]
                    new CIMSolidFill
                      Color = CIMColor.CreateRGBColor(0, 255, 0)
                UseRealWorldSymbolSizes = true
            MaxScale = 0,
            MinScale = 0,
            SymbolName = "TextSymbol-Green"
          StandardLabelPlacementProperties = new CIMStandardLabelPlacementProperties
            AllowOverlappingLabels = true,
            LineOffset = 1.0
          MaplexLabelPlacementProperties = new CIMMaplexLabelPlacementProperties
            AlignLabelToLineDirection = true,
            AvoidPolygonHoles = true
        // Blue label
        CIMLabelClass blueLabelClass = new CIMLabelClass
          Name = "Blue",
          ExpressionTitle = "Expression-Blue",
          ID = 2,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              FontFamilyName = "Consolas",
              HaloSize = 2.0,
                    new CIMSolidFill
                      Color = CIMColor.CreateRGBColor(0, 0, 255)
            MaxScale = 0,
            MinScale = 0,
            SymbolName = "TextSymbol-Blue"
            LineOffset = 1.0
        // Create a list of labels
        List<CIMLabelClass> labelClasses = new List<CIMLabelClass> { greenLabelClass, blueLabelClass };
        // Create an annotation feature class description object to describe the feature class to create
        AnnotationFeatureClassDescription annotationFeatureClassDescription =
          new AnnotationFeatureClassDescription(annotationFeatureClassName, fieldDescriptions, shapeDescription,
            generalPlacementProperties, labelClasses)
            IsAutoCreate = true,
            IsSymbolIDRequired = false,
            IsUpdatedOnShapeChange = true
        // Create a SchemaBuilder object
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Add the creation of the Cities annotation feature class to the list of DDL tasks
        schemaBuilder.Create(annotationFeatureClassDescription);
        // Execute the DDL
        bool success = schemaBuilder.Build();
        // Inspect error messages
        if (!success)
          IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
          //etc.
    Creating a feature-linked annotation feature class
      Task CreateFeatureLinkedAnnotationFeatureClassAsync(Geodatabase geodatabase,
        // Creating a feature-linked annotation feature class between water pipe and valve in water distribution network
        // PipeName
        // GlobalID
        string annotationFeatureClassName = "WaterPipeAnnotation";
        FieldDescription pipeGlobalID = FieldDescription.CreateGlobalIDField();
            { pipeGlobalID, nameFieldDescription };
        CIMMaplexGeneralPlacementProperties generalPlacementProperties = new CIMMaplexGeneralPlacementProperties
            R = 255,
            G = 0,
            B = 0,
            Alpha = 0.5f
        // Green label
          Name = "Green",
          ID = 1,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              HaloSize = 2.0,
                    new CIMSolidFill
            MaxScale = 0,
            MinScale = 0,
            LineOffset = 1.0
        // Blue label
          Name = "Blue",
          ID = 2,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              HaloSize = 2.0,
                    new CIMSolidFill
            MaxScale = 0,
            MinScale = 0,
            LineOffset = 1.0
        // Create linked feature description
        // Linked feature class name
        string linkedFeatureClassName = "WaterPipe";
        // Create fields for water pipe
        FieldDescription waterPipeGlobalID = FieldDescription.CreateGlobalIDField();
        FieldDescription pipeName = FieldDescription.CreateStringField("PipeName", 255);
        // Create a list of water pipe field descriptions
        List<FieldDescription> pipeFieldDescriptions = new List<FieldDescription> { waterPipeGlobalID, pipeName };
        // Create a linked feature class description
        FeatureClassDescription linkedFeatureClassDescription = new FeatureClassDescription(linkedFeatureClassName,
          pipeFieldDescriptions,
          new ShapeDescription(GeometryType.Polyline, spatialReference));
        // Add the creation of the linked feature class to the list of DDL tasks
        FeatureClassToken linkedFeatureClassToken = schemaBuilder.Create(linkedFeatureClassDescription);
            generalPlacementProperties, labelClasses, new FeatureClassDescription(linkedFeatureClassToken))
        // Add the creation of the annotation feature class to the list of DDL tasks
        // Execute the DDL
        if (!success)
          //etc.
    Requirements
