ArcGIS.Desktop.Editing Namespace / EditOperation Class / Create Method / Create(MapMember,KnowledgeGraphRelationshipDescription) Method
The relationship mapMember representing an association between two entities in a knowledge graph.
A description of the relationship to create.
Example
    Creates a new relationship between the two specified entities in the KnowledgeGraphRelationshipDescription.
    Syntax
    Parameters
    relationshipMapMember
    relationshipDescription
    Exceptions
    ExceptionDescription
    relationshipMapMember cannot be null.
    relationshipDescription cannot be null.
    The relationshipMapMember is either not part of a Knowledge Graph or not a Knowledge Graph relate type.
    Remarks
    The Create method creates a relationship between the origin entity and the destination entity specified in the RelationshipDescription.
    Example
    Create feature from a modified inspector
    // Creates a new feature by copying and optionally modifying the attributes of an existing feature using an inspector.
    await QueuedTask.Run(() =>
          // Create an inspector and load a feature
          // The inspector is used to modify the attributes of the feature before creating it
          var insp = new Inspector();
          insp.Load(featureLayer, objectId);
          // modify attributes if necessary
          // insp["Field1"] = newValue;
          //Create new feature from an existing inspector (copying the feature)
          var createOp = new EditOperation() { Name = "Create from insp" };
          createOp.Create(insp.MapMember, insp.ToDictionary(a => a.FieldName, a => a.CurrentValue));
          if (!createOp.IsEmpty)
            var result = createOp.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Create features from a CSV file
    // Creates new point features in the specified feature layer using data from a CSV source.
    var csvData = new List<(double X, double Y, double StopOrder, double FacilityID)>();
    //Run on MCT
      //Create the edit operation
      var createOperation = new ArcGIS.Desktop.Editing.EditOperation() { Name = "Generate points", SelectNewFeatures = false };
      // determine the shape field name - it may not be 'Shape'
      string shapeField = featureLayer.GetFeatureClass().GetDefinition().GetShapeField();
      //Loop through csv data
      foreach (var item in csvData)
        //Create the point geometry
        ArcGIS.Core.Geometry.MapPoint newMapPoint =
            ArcGIS.Core.Geometry.MapPointBuilderEx.CreateMapPoint(item.X, item.Y);
        // include the attributes via a dictionary
        var atts = new Dictionary<string, object>
            { "StopOrder", item.StopOrder },
            { "FacilityID", item.FacilityID },
            { shapeField, newMapPoint }
        // queue feature creation
        createOperation.Create(featureLayer, atts);
      // execute the edit (feature creation) operation
      if (createOperation.IsEmpty)
        return createOperation.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
      else
        return false;
    Create a record in a separate table in the Map within Row Events
    // attach an event handler to receive notifications when a new row is created in the
    // associated table of the first feature layer found in the active map. Use this method to enable custom logic in
    // response to row creation events within your ArcGIS Pro add-in.
    // subscribe to the RowCreatedEvent
    Table table = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable();
    RowCreatedEvent.Subscribe(rowChangedEventArgs =>
        // RowEvent callbacks are always called on the QueuedTask so there is no need
        // to wrap your code within a QueuedTask.Run lambda.
        // get the edit operation
        var parentEditOp = rowChangedEventArgs.Operation;
        // set up some attributes
        var attribs = new Dictionary<string, object>
          { "Layer", "Parcels" },
          { "Description", "objectId: " + rowChangedEventArgs.Row.GetObjectID().ToString() + " " + DateTime.Now.ToShortTimeString() }
        //create a record in an audit table
        var sTable = MapView.Active.Map.FindStandaloneTables("EditHistory")[0];
        var table = sTable.GetTable();
        parentEditOp.Create(table, attribs);
      }, table);
    Create a record in a separate table within Row Events
    // Attach an event handler to the <see cref="ArcGIS.Desktop.Editing.Events.RowCreatedEvent"/> for the table associated with the first <see cref="ArcGIS.Desktop.Mapping.FeatureLayer"/> in the active map. Use this method to monitor when new rows are created
    // in that table, enabling custom logic to be executed in response to record creation events.
    Table firstTable = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault().GetTable();
      // update a separate table not in the map when a row is created
      // You MUST use the ArcGIS.Core.Data API to edit the table. Do NOT
      // use a new edit operation in the RowEvent callbacks
      try
        // update Notes table with information about the new feature
        using var geoDatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(Project.Current.DefaultGeodatabasePath)));
        using var table = geoDatabase.OpenDataset<Table>("Notes");
      catch (Exception e)
        throw new Exception($@"Error in OnRowCreated for objectId: {rowChangedEventArgs.Row.GetObjectID()} : {e}");
    }, firstTable);
    Create a new Relationship from Existing Entities 2
      var create_rel2 = await QueuedTask.Run(() =>
        //Instantiate an operation for the Create
        var edit_op = new EditOperation()
          Name = "Create a new relationship record",
          SelectNewFeatures = true
        //Use datasets or feature layer(s) or standalone table(s)
        //Get a reference to the KnowledgeGraph
        //var kg = ... ;
        //We will use a relate called 'HasEmployee' to relate an Organization w/ a Person
        //Use either tables or map members to get the rows to be related...
        var org_fc = kg.OpenDataset<FeatureClass>("Organization");
        var person_tbl = kg.OpenDataset<Table>("Person");
        //Get the relationship dataset
        //We can use either a table or standalone table
        var emp_tbl = kg.OpenDataset<Table>("HasEmployee");
        // get the origin, destination records
        Guid guidOrigin = Guid.Empty;
        Guid guidDestination = Guid.Empty;
        using (var rc = org_fc.Search())
          if (rc.MoveNext())
            //Use the KnowledgeGraphPropertyInfo to avoid hardcoding...
            guidOrigin = rc.Current.GetGlobalID();
        using (var rc = person_tbl.Search())
          if (rc.MoveNext())
            guidDestination = rc.Current.GetGlobalID();
        //Add any extra attribute information for the relation as needed
        var attribs = new Dictionary<string, object>();
        attribs["StartDate"] = new DateTimeOffset(DateTime.Now);
        var rd = new KnowledgeGraphRelationshipDescription(guidOrigin, guidDestination, attribs);
        //Add a create for the relationship to the operation
        edit_op.Create(emp_tbl, rd);
        //Do the create
        return edit_op.Execute();
    Create a new Relationship and New Entities 2
      var mv = MapView.Active;
      var createRel = await QueuedTask.Run(() =>
        //This example uses a KnowledgeGraphRelationshipDescription
          Name = "Create entities and a relationship using a KG relate desc",
        //We are just going to use mapmembers in this example
        //we could equally use feature classes/tables
        var kg_layer = mv.Map.GetLayersAsFlattenedList()?
                      .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>().First();
        //From the KG Layer get the relevant child feature layer(s) and/or standalone
        //table(s)
        var org_fl = kg_layer.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                        .First(child_layer => child_layer.Name == "Organization");
        var person_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "Person");
        var rel_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "HasEmployee");
        //New Organization
        attribs["Name"] = "Acme Ltd.";
        attribs["Description"] = "Specializes in household items";
        attribs["SHAPE"] = mv.Extent.Center;//whatever is its location
        //Add it to the operation - we need the rowtoken
        var rowtoken_org = edit_op.Create(org_fl, attribs);
        attribs.Clear();//we are going to re-use the dictionary
        //New Person
        attribs["Name"] = "Bob";
        attribs["Age"] = "41";
        attribs["Skills"] = "Plumbing, Framing, Flooring";
        var rowtoken_person = edit_op.Create(person_stbl, attribs);
        attribs.Clear();
        //Create the new relationship using a KnowledgeGraphRelationshipDescription
        //Row handles act as the placeholders for the TO BE created new entities that will
        //be related
        var src_row_handle = new RowHandle(rowtoken_org);
        var dest_row_handle = new RowHandle(rowtoken_person);
        var rel_desc = new KnowledgeGraphRelationshipDescription(
                                    src_row_handle, dest_row_handle, attribs);
        //Add the relate description to the edit operation
        edit_op.Create(rel_stbl, rel_desc);
        //Execute the create of the entities and relationship
    Create an Entity, a Document, a HasDocument and a Provenance record
          Name = "Create a records",
        // create the entity
        var personToken = edit_op.Create(personLayer, personAtts);
        // create the document
        var kgDocDesc = new KnowledgeGraphDocumentDescription(
          @"D:\Data\BirthCertificate.jpg");
        var docToken = edit_op.Create(docLayer, kgDocDesc);
        // create RowHandles from the returned RowTokens
        var personHandle = new RowHandle(personToken);
        var docHandle = new RowHandle(docToken);
        // create the "hasDocument" relationship
        var rd = new KnowledgeGraphRelationshipDescription(personHandle, docHandle);
        edit_op.Create(docLayer, rd);
        // create the provenance record for the person entity using the document entity
        // provenance record is on the "name" field
        var pd = new KnowledgeGraphProvenanceDescription(
          personHandle, "name", docHandle, "", "comments");
        edit_op.Create(pd);
        // execute - create all the entities and relationship rows _together_
        edit_op.Execute();
    Create a Document Record 2
        using (var kg_for_doc = kgLayer.GetDatastore())
          var propInfo = kg_for_doc.GetPropertyNameInfo();
          if (!propInfo.SupportsDocuments)
            return false;
            Name = "Create Document Example",
          var doc_entity_name = propInfo.DocumentTypeName;
          var hasdoc_rel_name = GetHasDocumentTypeName(kg.GetDataModel());
          //Document can also be FeatureClass
          var doc_tbl = kg_for_doc.OpenDataset<Table>(doc_entity_name);
          var doc_rel_tbl = kg_for_doc.OpenDataset<Table>(hasdoc_rel_name);
          //This is the document to be added...file, image, resource, etc.
          var doc_url = @"E:\Data\Temp\HelloWorld.txt";
          // create the KnowledgeGraphDocumentDescription
          var kgDocDesc = new KnowledgeGraphDocumentDescription(doc_url);
          // if there is a geometry use the following ctor
          // var kgDocDesc = new KnowledgeGraphDocumentDescription(doc_url, doc_location);
          // if you have additional custom attributes
          //var customDocAtts = new Dictionary<string, object>();
          //customDocAtts.Add("custom_attrib", "Foo");
          //customDocAtts.Add("custom_attrib2", "Bar");
          //var kgDocDesc = new KnowledgeGraphDocumentDescription(url, null, customDocAtts);
          // add additional properties if required
          kgDocDesc.Keywords = @"text,file,example";
          // The Create method will auto-populate the Url, Name, FileExtension and contentType fields of the document row
          // from the path supplied.
          var rowToken = edit_op.Create(doc_tbl, kgDocDesc);
          //Get the entity whose document this is...
          var org_fc = kg_for_doc.OpenDataset<FeatureClass>("Organization");
          var qf = new ArcGIS.Core.Data.QueryFilter()
            WhereClause = "name = 'Acme'",
            SubFields = "*"
          var origin_org_id = Guid.Empty;
          using (var rc = org_fc.Search(qf))
            if (!rc.MoveNext())
              return false;
            origin_org_id = rc.Current.GetGlobalID();//For the relate
          // set up the row handles
          var originHandle = new RowHandle(org_fc, origin_org_id);    // entity
          var destinationHandle = new RowHandle(rowToken);            // document
          // create the KnowledgeGraphRelationshipDescription
          var rd = new KnowledgeGraphRelationshipDescription(originHandle, destinationHandle);
          // if you have additional custom attributes for the "HasDocument" relationship
          //var customHasDocAtts = new Dictionary<string, object>();
          //customHasDocAtts.Add("custom_attrib", "Foo");
          //customHasDocAtts.Add("custom_attrib2", "Bar");
          //var rd = new KnowledgeGraphRelationshipDescription(originHandle, destinationHandle, customHasDocAtts);
          // create the relate record using the same edit operation
          edit_op.Create(doc_rel_tbl, rd);
          //Call execute to create all the entities and relationship rows _together_
    Requirements
    ArcGIS Pro version: 3.4 or higher.
