ArcGIS.Desktop.Editing Namespace / EditOperation Class / Delete Method / Delete(MapMember,KnowledgeGraphRelationshipDescription) Method
The relationship mapMember representing an association between two entities in a knowledge graph.
A description of the relationship to delete.
Example
    Deletes a relationship between the two specified entities in the KnowledgeGraphRelationshipDescription.
    Syntax
    Parameters
    relationshipMapMember
    relationshipDescription
    Exceptions
    ExceptionDescription
    relationshipMapMember cannot be null.
    relationshipDescription cannot be null.
    The relationshipMapMember is either not part of a Knowledge Graph or not a Knowledge Graph relate type.
    Remarks
    The Delete method removes a relationship between the origin entity and the destination entity specified in the RelationshipDescription.
    Example
    Delete a Relationship record 2
      var mv = MapView.Active;
      await QueuedTask.Run(() =>
        var edit_op = new EditOperation()
          Name = "Delete a Relationship record"
        //We are  going to use mapmembers in this example
        //we could equally use feature classes/tables
        var kg_layer = mv.Map.GetLayersAsFlattenedList()?
                      .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>().First();
        //entities
        var entityOrg = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "Organization");
        var entityPerson = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "Person");
        //Relationship
        var rel_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "HasEmployee");
        // get the origin, destination records
        Guid guidOrigin = Guid.Empty;
        Guid guidDestination = Guid.Empty;
        using (var rc = entityOrg.Search())
          if (rc.MoveNext())
            //Use the KnowledgeGraphPropertyInfo to avoid hardcoding...
            guidOrigin = rc.Current.GetGlobalID();
        using (var rc = entityPerson.Search())
          if (rc.MoveNext())
            guidDestination = rc.Current.GetGlobalID();
        var rd = new KnowledgeGraphRelationshipDescription(guidOrigin, guidDestination);
        edit_op.Delete(rel_stbl, rd);
        edit_op.Execute();//Do the delete
    Requirements
    ArcGIS Pro version: 3.4 or higher.
