Public NotInheritable Class TopologyDefinition Inherits ArcGIS.Core.Data.Definition Implements System.IDisposable
public sealed class TopologyDefinition : ArcGIS.Core.Data.Definition, System.IDisposable
// Builds the map topology graph for the active map view and displays the number of topology nodes and edges. await QueuedTask.Run(() => { //Build the map topology graph MapView.Active.BuildMapTopologyGraph<TopologyDefinition>(topologyGraph => { //Getting the nodes and edges present in the graph var topologyGraphNodes = topologyGraph.GetNodes(); var topologyGraphEdges = topologyGraph.GetEdges(); foreach (var node in topologyGraphNodes) { // do something with the node } foreach (var edge in topologyGraphEdges) { // do something with the edge } MessageBox.Show($"Number of topo graph nodes are: {topologyGraphNodes.Count}.\n Number of topo graph edges are {topologyGraphEdges.Count}.", "Map Topology Info"); }); });
static void OpenTopologyAndProcessDefinition()
// Open a geodatabase topology from a file geodatabase and process the topology definition.
using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
ProcessDefinition(geodatabase, topology);
// Open a feature service topology and process the topology definition.
const string TOPOLOGY_LAYER_ID = "0";
using (Geodatabase geodatabase = new Geodatabase(new ServiceConnectionProperties(new Uri("https://sdkexamples.esri.com/server/rest/services/GrandTeton/FeatureServer"))))
using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>(TOPOLOGY_LAYER_ID))
static void ProcessDefinition(Geodatabase geodatabase, ArcGIS.Core.Data.Topology.Topology topology)
// Similar to the rest of the Definition objects in the Core.Data API, there are two ways to open a dataset's
// definition -- via the Topology dataset itself or via the Geodatabase.
using (TopologyDefinition definitionViaTopology = topology.GetDefinition())
OutputDefinition(geodatabase, definitionViaTopology);
using (TopologyDefinition definitionViaGeodatabase = geodatabase.GetDefinition<TopologyDefinition>("Backcountry_Topology"))
OutputDefinition(geodatabase, definitionViaGeodatabase);
static void OutputDefinition(Geodatabase geodatabase, TopologyDefinition topologyDefinition)
Console.WriteLine($"Topology cluster tolerance => {topologyDefinition.GetClusterTolerance()}");
Console.WriteLine($"Topology Z cluster tolerance => {topologyDefinition.GetZClusterTolerance()}");
IReadOnlyList<string> featureClassNames = topologyDefinition.GetFeatureClassNames();
Console.WriteLine($"There are {featureClassNames.Count} feature classes that are participating in the topology:");
foreach (string name in featureClassNames)
// Open each feature class that participates in the topology.
using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>(name))
using (FeatureClassDefinition featureClassDefinition = featureClass.GetDefinition())
Console.WriteLine($"\t{featureClass.GetName()} ({featureClassDefinition.GetShapeType()})");
System.Object
ArcGIS.Core.CoreObjectsBase
ArcGIS.Core.Data.Topology.TopologyDefinition
