ArcGIS.Core.Data.Topology Namespace / TopologyDefinition Class / GetZClusterTolerance Method
Example
    Gets the Z cluster tolerance of the topology. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetZClusterTolerance() As Double
    public double GetZClusterTolerance()
    Return Value
    The cluster tolerance of the topology.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Open topology and process definition
      static void OpenTopologyAndProcessDefinition()
        // Open a geodatabase topology from a file geodatabase and process the topology definition.
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          ProcessDefinition(geodatabase, topology);
        // Open a feature service topology and process the topology definition.
        const string TOPOLOGY_LAYER_ID = "0";
        using (Geodatabase geodatabase = new Geodatabase(new ServiceConnectionProperties(new Uri("https://sdkexamples.esri.com/server/rest/services/GrandTeton/FeatureServer"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>(TOPOLOGY_LAYER_ID))
        static void ProcessDefinition(Geodatabase geodatabase, ArcGIS.Core.Data.Topology.Topology topology)
          // Similar to the rest of the Definition objects in the Core.Data API, there are two ways to open a dataset's
          // definition -- via the Topology dataset itself or via the Geodatabase.
          using (TopologyDefinition definitionViaTopology = topology.GetDefinition())
            OutputDefinition(geodatabase, definitionViaTopology);
          using (TopologyDefinition definitionViaGeodatabase = geodatabase.GetDefinition<TopologyDefinition>("Backcountry_Topology"))
            OutputDefinition(geodatabase, definitionViaGeodatabase);
        static void OutputDefinition(Geodatabase geodatabase, TopologyDefinition topologyDefinition)
          Console.WriteLine($"Topology cluster tolerance => {topologyDefinition.GetClusterTolerance()}");
          Console.WriteLine($"Topology Z cluster tolerance => {topologyDefinition.GetZClusterTolerance()}");
          IReadOnlyList<string> featureClassNames = topologyDefinition.GetFeatureClassNames();
          Console.WriteLine($"There are {featureClassNames.Count} feature classes that are participating in the topology:");
          foreach (string name in featureClassNames)
            // Open each feature class that participates in the topology.
            using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>(name))
            using (FeatureClassDefinition featureClassDefinition = featureClass.GetDefinition())
              Console.WriteLine($"\t{featureClass.GetName()} ({featureClassDefinition.GetShapeType()})");
    Requirements
