ArcGIS.Core.Data.Topology Namespace / TopologyEdge Class / GetFromNode Method
Example
    GetFromNode Method
    Gets the topology node at the from point of this edge. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetFromNode() As TopologyNode
    public TopologyNode GetFromNode()
    Return Value
    The topology node at the from point of this edge.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Explore topology graph
      static void ExploreTopologyGraph()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          // Build a topology graph using the extent of the topology dataset.
          topology.BuildGraph(topology.GetExtent(), (topologyGraph) =>
            using (Feature campsites12 = GetFeature(geodatabase, "Campsites", 12))
              IReadOnlyList<TopologyNode> topologyNodesViaCampsites12 = topologyGraph.GetNodes(campsites12);
              TopologyNode topologyNodeViaCampsites12 = topologyNodesViaCampsites12[0];
              IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12 = topologyNodeViaCampsites12.GetEdges();
              IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12CounterClockwise = topologyNodeViaCampsites12.GetEdges(false);
              foreach (TopologyEdge edgeConnectedToNodeViaCampsites12 in allEdgesConnectedToNodeViaCampsites12)
                TopologyNode fromNode = edgeConnectedToNodeViaCampsites12.GetFromNode();
                TopologyNode toNode = edgeConnectedToNodeViaCampsites12.GetToNode();
                bool fromNodeIsTheSameAsTopologyNodeViaCampsites12 = (fromNode == topologyNodeViaCampsites12);
                bool toNodeIsTheSameAsTopologyNodeViaCampsites12 = (toNode == topologyNodeViaCampsites12);
                IReadOnlyList<FeatureInfo> leftParentFeaturesBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures();
                foreach (FeatureInfo featureInfo in leftParentFeaturesBoundedByEdge)
                  EnsureShapeIsNotEmpty(featureInfo);
                IReadOnlyList<FeatureInfo> leftParentFeaturesNotBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures(false);
                foreach (FeatureInfo featureInfo in leftParentFeaturesNotBoundedByEdge)
                IReadOnlyList<FeatureInfo> rightParentFeaturesBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetRightParentFeatures();
                foreach (FeatureInfo featureInfo in rightParentFeaturesBoundedByEdge)
                IReadOnlyList<FeatureInfo> rightParentFeaturesNotBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetRightParentFeatures(false);
                foreach (FeatureInfo featureInfo in rightParentFeaturesNotBoundedByEdge)
        static void EnsureShapeIsNotEmpty(FeatureInfo featureInfo)
          using (Feature feature = featureInfo.GetFeature())
            // Process feature ...
    Requirements
