ArcGIS.Core.Data.Topology Namespace / TopologyNode Class
Members Example
    TopologyNode Class
    Represents a topological node within a topology graph.
    Object Model
    TopologyNode ClassGeometry Class
    Syntax
    Example
    Build Map Topology
    // Builds the map topology graph for the active map view and displays the number of topology nodes and edges.
    await QueuedTask.Run(() =>
      //Build the map topology graph
      MapView.Active.BuildMapTopologyGraph<TopologyDefinition>(topologyGraph =>
        //Getting the nodes and edges present in the graph
        var topologyGraphNodes = topologyGraph.GetNodes();
        var topologyGraphEdges = topologyGraph.GetEdges();
        foreach (var node in topologyGraphNodes)
          // do something with the node
        foreach (var edge in topologyGraphEdges)
          // do something with the edge
        MessageBox.Show($"Number of topo graph nodes are:  {topologyGraphNodes.Count}.\n Number of topo graph edges are {topologyGraphEdges.Count}.", "Map Topology Info");
    Explore topology graph
      static void ExploreTopologyGraph()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          // Build a topology graph using the extent of the topology dataset.
          topology.BuildGraph(topology.GetExtent(), (topologyGraph) =>
            using (Feature campsites12 = GetFeature(geodatabase, "Campsites", 12))
              IReadOnlyList<TopologyNode> topologyNodesViaCampsites12 = topologyGraph.GetNodes(campsites12);
              TopologyNode topologyNodeViaCampsites12 = topologyNodesViaCampsites12[0];
              IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12 = topologyNodeViaCampsites12.GetEdges();
              IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12CounterClockwise = topologyNodeViaCampsites12.GetEdges(false);
              foreach (TopologyEdge edgeConnectedToNodeViaCampsites12 in allEdgesConnectedToNodeViaCampsites12)
                TopologyNode fromNode = edgeConnectedToNodeViaCampsites12.GetFromNode();
                TopologyNode toNode = edgeConnectedToNodeViaCampsites12.GetToNode();
                bool fromNodeIsTheSameAsTopologyNodeViaCampsites12 = (fromNode == topologyNodeViaCampsites12);
                bool toNodeIsTheSameAsTopologyNodeViaCampsites12 = (toNode == topologyNodeViaCampsites12);
                IReadOnlyList<FeatureInfo> leftParentFeaturesBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures();
                foreach (FeatureInfo featureInfo in leftParentFeaturesBoundedByEdge)
                  EnsureShapeIsNotEmpty(featureInfo);
                IReadOnlyList<FeatureInfo> leftParentFeaturesNotBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures(false);
                foreach (FeatureInfo featureInfo in leftParentFeaturesNotBoundedByEdge)
                IReadOnlyList<FeatureInfo> rightParentFeaturesBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetRightParentFeatures();
                foreach (FeatureInfo featureInfo in rightParentFeaturesBoundedByEdge)
                IReadOnlyList<FeatureInfo> rightParentFeaturesNotBoundedByEdge =
                  edgeConnectedToNodeViaCampsites12.GetRightParentFeatures(false);
                foreach (FeatureInfo featureInfo in rightParentFeaturesNotBoundedByEdge)
        static void EnsureShapeIsNotEmpty(FeatureInfo featureInfo)
          using (Feature feature = featureInfo.GetFeature())
            // Process feature ...
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Topology.TopologyElement
             ArcGIS.Core.Data.Topology.TopologyNode
    Requirements
