ArcGIS.Core.Data.Topology Namespace / TopologyNode Class
Properties Methods
    TopologyNode Class Members
    The following tables list the members exposed by TopologyNode.
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public MethodOverloaded.
    Public Method Gets the set of topological edges that are coincident with this node. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Gets a hash code for the current object.
    Public Method Gets the parent feature(s) that spawn this topology element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Topology.TopologyElement)
    Public Method Gets the shape of this topology element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Topology.TopologyElement)
    Public Method Gets a value indicating whether this topology element has been visited. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Topology.TopologyElement)
    Public Method Sets a value indicating whether this topology element has been visited. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Topology.TopologyElement)
    Top
    Public Operators
    Determines whether two TopologyNode instances are equal.
    Determines whether two TopologyNode instances are not equal.
    Top
