ArcGIS.Core.Data.Topology Namespace / TopologyElement Class / GetParentFeatures Method
Example
    Gets the parent feature(s) that spawn this topology element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetParentFeatures() As IReadOnlyList(Of FeatureInfo)
    public IReadOnlyList<FeatureInfo> GetParentFeatures()
    Return Value
    A list of one or more parent features that spawn this topology element.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Find closest element from a topology graph
      static void FindClosestElement()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          // Build a topology graph using the extent of the topology dataset.
          topology.BuildGraph(topology.GetExtent(), (topologyGraph) =>
            MapPoint queryPointViaCampsites12 = null;
            using (Feature campsites12 = GetFeature(geodatabase, "Campsites", 12))
              queryPointViaCampsites12 = campsites12.GetShape() as MapPoint;
            double searchRadius = 1.0;
            TopologyElement topologyElementViaCampsites12 = topologyGraph.FindClosestElement<TopologyElement>(queryPointViaCampsites12, searchRadius);
            IReadOnlyList<FeatureInfo> parentFeatures = topologyElementViaCampsites12.GetParentFeatures();
            Console.WriteLine("The parent features that spawn 'topologyElementViaCampsites12' are:");
            foreach (FeatureInfo parentFeature in parentFeatures)
              Console.WriteLine($"\t{parentFeature.FeatureClassName}; OID: {parentFeature.ObjectID}");
            TopologyNode topologyNodeViaCampsites12 = topologyGraph.FindClosestElement<TopologyNode>(queryPointViaCampsites12, searchRadius);
            if (topologyNodeViaCampsites12 != null)
              // There exists a TopologyNode nearest to the query point within searchRadius units.
            TopologyEdge topologyEdgeViaCampsites12 = topologyGraph.FindClosestElement<TopologyEdge>(queryPointViaCampsites12, searchRadius);
            if (topologyEdgeViaCampsites12 != null)
              // There exists a TopologyEdge nearest to the query point within searchRadius units.
    Requirements
