ArcGIS.Core.Data.Topology Namespace / TopologyElement Class
Properties Methods
    TopologyElement Class Members
    The following tables list the members exposed by TopologyElement.
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public MethodOverloaded.
    Public Method Gets a hash code for the current object.
    Public Method Gets the parent feature(s) that spawn this topology element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the shape of this topology element. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value indicating whether this topology element has been visited. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets a value indicating whether this topology element has been visited. This method must be called on the MCT. Use QueuedTask.Run.
    Top
    Public Operators
    Determines whether two TopologyElement instances are equal.
    Determines whether two TopologyElement instances are not equal.
    Top
