ArcGIS.Core.Data.Topology Namespace / TopologyElement Class / Inequality Operator
The object to compare with topologyElement2.
The object to compare with topologyElement1.
    Inequality Operator (TopologyElement)
    Determines whether two TopologyElement instances are not equal.
    Syntax
    Parameters
    topologyElement1
    topologyElement2
    Return Value
    true if topologyElement1 is not equal to topologyElement2; otherwise, false.
    Remarks
    Semantically, if two managedTopologyElement instances refer to the same backing nativeTopologyElement instance in native code, they are considered equal.
    Requirements
