ArcGIS.Core.Data.Topology Namespace / TopologyNode Class / Inequality Operator
The object to compare with topologyNode2.
The object to compare with topologyNode1.
    Inequality Operator (TopologyNode)
    Determines whether two TopologyNode instances are not equal.
    Syntax
    Parameters
    topologyNode1
    topologyNode2
    Return Value
    true if topologyNode1 is not equal to topologyNode2; otherwise, false.
    Remarks
    Semantically, if two managedTopologyNode instances refer to the same backing nativeTopologyNode instance in native code, they are considered equal.
    Requirements
