ArcGIS.Core.Data.Topology Namespace / TopologyError Class
Members Example
    TopologyError Class
    Represents an error associated with a Topology.
    Object Model
    TopologyError ClassGeometry Class
    Syntax
    Public NotInheritable Class TopologyError
    public sealed class TopologyError
    Example
    Process topology errors
      static void ProcessTopologyErrors()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          // Get all the errors and exceptions currently associated with the topology.
          IReadOnlyList<TopologyError> allErrorsAndExceptions = topology.GetErrors(new ErrorDescription(topology.GetExtent()));
          Console.WriteLine($"errors and exceptions count => {allErrorsAndExceptions.Count}");
          Console.WriteLine("OriginClassName \t OriginObjectID \t DestinationClassName \t DestinationObjectID \t RuleType \t IsException \t Shape type \t Shape width & height \t  Rule ID \t");
          foreach (TopologyError error in allErrorsAndExceptions)
            Console.WriteLine(
              $"'{error.OriginClassName}' \t {error.OriginObjectID} \t '{error.DestinationClassName}' \t " +
              $"{error.DestinationObjectID} \t {error.RuleType} \t {error.IsException} \t {error.Shape.GeometryType} \t " +
              $"{error.Shape.Extent.Width},{error.Shape.Extent.Height} \t {error.RuleID}");
    Mark and unmark errors or exceptions
      static void MarkAndUnmarkAsErrors(ArcGIS.Core.Data.Topology.Topology topology)
        // Get all the errors due to features violating the "PointProperlyInsideArea" topology rule.
        using (TopologyDefinition topologyDefinition = topology.GetDefinition())
          TopologyRule pointProperlyInsideAreaRule = topologyDefinition.GetRules().First(rule => rule.RuleType == TopologyRuleType.PointProperlyInsideArea);
          ErrorDescription errorDescription = new ErrorDescription(topology.GetExtent())
            TopologyRule = pointProperlyInsideAreaRule
          IReadOnlyList<TopologyError> errorsDueToViolatingPointProperlyInsideAreaRule = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsDueToViolatingPointProperlyInsideAreaRule.Count} feature violating the 'PointProperlyInsideArea' topology rule.");
          // Mark all errors from features violating the 'PointProperlyInsideArea' topology rule as exceptions.
          foreach (TopologyError error in errorsDueToViolatingPointProperlyInsideAreaRule)
            topology.MarkAsException(error);
          // Now verify all the errors from features violating the 'PointProperlyInsideArea' topology rule have indeed been
          // marked as exceptions.
          // By default, ErrorDescription is initialized to ErrorType.ErrorAndException.  Here we want ErrorType.ErrorOnly.
            ErrorType = ErrorType.ErrorOnly,
          IReadOnlyList<TopologyError> errorsAfterMarkedAsExceptions = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsAfterMarkedAsExceptions.Count} feature violating the 'PointProperlyInsideArea' topology rule after all the errors have been marked as exceptions.");
          // Finally, reset all the exceptions as errors by unmarking them as exceptions.
            topology.UnmarkAsException(error);
          IReadOnlyList<TopologyError> errorsAfterUnmarkedAsExceptions = topology.GetErrors(errorDescription);
          Console.WriteLine($"There are {errorsAfterUnmarkedAsExceptions.Count} feature violating the 'PointProperlyInsideArea' topology rule after all the exceptions have been reset as errors.");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.Topology.TopologyError
    Requirements
