ArcGIS.Core.Data.Topology Namespace / TopologyError Class / OriginClassName Property
Example
    OriginClassName Property (TopologyError)
    Gets the feature class name of the origin feature that created the topology error. If it is not applicable, an empty string is returned.
    Syntax
    Public ReadOnly Property OriginClassName As String
    public string OriginClassName {get;}
    Example
    Process topology errors
      static void ProcessTopologyErrors()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          // Get all the errors and exceptions currently associated with the topology.
          IReadOnlyList<TopologyError> allErrorsAndExceptions = topology.GetErrors(new ErrorDescription(topology.GetExtent()));
          Console.WriteLine($"errors and exceptions count => {allErrorsAndExceptions.Count}");
          Console.WriteLine("OriginClassName \t OriginObjectID \t DestinationClassName \t DestinationObjectID \t RuleType \t IsException \t Shape type \t Shape width & height \t  Rule ID \t");
          foreach (TopologyError error in allErrorsAndExceptions)
            Console.WriteLine(
              $"'{error.OriginClassName}' \t {error.OriginObjectID} \t '{error.DestinationClassName}' \t " +
              $"{error.DestinationObjectID} \t {error.RuleType} \t {error.IsException} \t {error.Shape.GeometryType} \t " +
              $"{error.Shape.Extent.Width},{error.Shape.Extent.Height} \t {error.RuleID}");
    Requirements
